Question about Honda Garden
Was using our powerwasher,,it;s 3 yrs old..have only used it 4 times...and the water just stopped coming outta the gun...my husband thnks the pump went on it...we have only used it 4 times..
    Sergeant:
  • 259 Answers
On the round piece that the garden hose screws too there is a filter screen in there. Remove it gently with a screwdriver around the edges and clean the screen then put it back in.
Posted on Mar 16, 2011
  • Anonymous Mar 16, 2011
    thank you,,i will try this in the morning,
Why doesnt my powerwasher pump out water
check for a blocked jet in the end of the wand ( squashed hoses or blocked hose to the wand)
the blocked jet has the same affect as not pulling the trigger and the pressure regulator bypasses the water back into the pump
Sep 08, 2015 | Annovi Reverberi RMV2.5G27D Pressure...
I have a Dewalt DPD3100, 2 yrs old, never had any problem, water supply hose is attached, water is going in but no water out?
Take the hose off the gun and see if water comes out. If so the gun has to be taken apart and cleaned. Also where the water hose goes in to the machine there is a screen filter which you might have to clean if water is not comming out on the gun side. Use a screwdriver and pry it out carefully around the edges Clean the screen with a wire brush and put it back in and try it.
Mar 20, 2011 | Dewalt DPD3100 Gas Pressure Washer
1997 ford escort 2.0L engine is overheating. it has a radiator that is 3 yrs. old, a new head gasket, re-machine heads, water pump and timing belt that are 2 yrs. old, new thermostat and several radiator...
try this,wearing rubber gloves(cos its hot)undo the topmost hot hose clip and expell any air trapped.also use a hotwire to check
electric fan(s) if fitted.if they run it aint them.do they operate when idling and hot,if not then its the sensor.or if you have a viscous fan is that working.....when hot you will feel a resistance to turning by hand when the engine is stopped..another telltail that the thermostat is gone is,does the guage go down when you turn the fan on full heat for the interior??...cant think of anything else.....
Sep 15, 2010 | 1996 Ford Escort 4 Door
IT IS ABOUT 4 YRS OLD AND THE WATER STARTED TO
I would not advise using bleach. I would disconnect the pipe from both ends and blow down it, either by mouth or air gun to ensure of no blockages. You should poor away at least 10 cups of water after changing filter to ensure clean fresh water.
Dec 15, 2009 | KitchenAid Superba KSRG25FK Side by Side...
It suddenly stopped working. It is 3 yrs old.
i restore my opperatting sistem and cant access my drivers again
Aug 31, 2009 | Dolphin Maytronics Diagnostic Robot...
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
My dishwasher is sticks in between washing cycles
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Jan 30, 2018 | Siemens 24 in. SE64A630GB Built-In...
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Washer fills then stops
there are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Jan 12, 2009 | Washing Machines
Garden Logo
55 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
