Question about Panasonic DVD-LS50 Portable DVD Player
The Ho2 came up - what do I do to get it to work?
  • 1 more comment
  • iwillwanda Mar 16, 2011
    When I turn on the DVD player Ho2 comes up
    That's all there is - everything else works
    please tell me what to do
    I did as you said but Ho2 still comes up!
    I'm sorry, but I'm not mechanically inclined - I'm a single female and wouldn't begin to do what you said, because I don't know how and I feel I'd break my DVD I am visual so if you can tell me where I can see it that might work but I don't know ribbon wire , lens, main board or connector parts duh and I'm not blond - smile
    Genius:
  • 1,043 Answers
The error code Ho2 is the self diagnostic program of the player telling you that there is a problem with either the spindle servo, the DSC SP motor, or a CLV servo error. Basically, all of those parts mentioned are the electronics that control the speed of the player so that the DVD's will play back properly on the player.
There is one minor process you can try yourself that may get the motor spinning again. You may have already tried this, and if you have I apologize for repeating the instructions. The unit is fairly easy to take apart. First make sure that the unit is not plugged in. Remove the lid of the player. Then plug the power back in. Using your remote control open the tray and put in a DVD that you know will work on the unit. Then close the tray. There is a white plastic wheel on the top that you can give a gentle nudge to see if it will start to spin. If it does then you should be okay. If it doesn't start spinning, then you may have one or more issues with the parts that I mentioned at the beginning of this repair process. Unless you have the proper tools and experience to start troubleshooting those parts then you will have to take the unit in to a Panasonic repair center. Of course if you still have a warranty I would not try to take the unit apart at all, but take it straight to the repair center.
Here is a link that you can go to and download a copy of the service manual for your player. If you want to try and take it apart to see if you can get the wheel turning this will help you to take it apart. If you look at section 7.1, it will step you through the steps you need to do to take the lid off and try and spin the motor manually to see if it will keep spinning. If you know someone who has the experience and the tools, they can use the manual to check all of the parts that I have mentioned in the first paragraph. Here is the link for the service manual:
http://elektrotanya.com/panasonic_dvd-ls50_sm.pdf/download.html
Remember that if you have any warranty left let the repair center do the checking and repairing for you.
Posted on Mar 16, 2011
    President:
  • 1,961 Answers
HO2 means the disc is not spinning. It was stuck temporarily. But it will not spin unless a little help is apply.
There is nothing wrong with the lens or the motor.
What you need to do is open the DVD player and/or try removing lid cover.
Power on the unit. and put a disc in it.
Use your finger to gently spin the disc counterclockwise.
This will fix it.
  • Danilo Baraquiel
    Danilo Baraquiel Mar 16, 2011
    try re inserting the ribbon wire from the lens to the main board make sure it snap in to the connector.thanks and post back for further question
    Top Expert:
  • Panasonic Master
  • 74,243 Answers
Hello
I thinks that you haven't the user manual of your device with you. If so, either send me your email address by Fixya, or mail me at gopakumarg43@ymail.com. i'll send it to you by return mail. It is an Adobe Acrobar Reader document [ printable version]., and you must have installed adobe reader in your system to read it properly. OK.
  • The Knight
    The Knight Mar 16, 2011
    Hello
    It is an error messege and has indicated in its user manual. I'll send it to you. There are three main error displays can be seen. They are
    ERROR 01"
    ERROR 02"
    ERROR 03"
    "H σσ"
    σσ stands for a
    number
    H o1:
    A problem has occurred with the battery pack. Consult your dealer.
    H02
    The battery pack has been recharging for 12 hours but has failed to
    recharge for some reason. Recharge again.
    h03:
    You are recharging in a location that is too hot or too cold. Recharge
    at normal temperature [
    i5 to i35 oC (i41 to i95 oF)].
    Trouble has occurred. The number appearing after "H" depends on
    the problem. Turn the unit off and on again. Alternatively, turn the unit
    off, disconnect the power source (AC or battery pack) reconnect the
    power and turn the unit on again.
    If the service numbers fail to clear, note the service number and
    consult your dealer.
    Press
    [, -OFF], then retry the operation again
    Refer for more details to its user manaul
    OK
    "H σσ"
    σσ stands for a
    number
    H o1:
    H02
    h03:
    Press [, -OFF], then retry the operation again
    OK
Where is h02 sensor on 99 4cl. camry
although the picture is of a 6 cly model the location is the same HO2 sensors are mounted in the exhaust system before and after the catalyst HO2..1 is the up stream Before the cat and HO2...2 is down stream of the cat if your code is bank one sensor 1 its the upstream and bank one sensor 2 is the downstream
Jan 03, 2013 | 1997 Saturn SL
My DVD player won't play i'm getting a code HO2 on the display screen. ModeL # DVD-RV31
this is what i got from Josh Smith Online, this work-around requires opening the appliance, so before you start and follow this, please check on the warranty status of the unit.
error HO2 which more or less means the unit is shot. The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player .
You can see the tray which rotates with the DVD in. To fix this HO2 error I first had to start the spin by pushing the dvd counterclockwise gently. After that the DVD player would work but only without the cover on. This is the solution for now, though I plan to modify the case some in order to use the cover again. For now the DVD player slides into our entertainment stand and hides the fact that the cover is missing.
Aug 11, 2008 | Panasonic Televison & Video
I cannot find the oxygen sensors on a 1997 ford explorer
well since they are located in the exhaust system start in engine compartment at the exhaust manifolds and and work your way back. depending on engine size and whether or not the exhaust is dual or comes together as one the best spot to check is at the catalyst. see there are different types and could be one bigger one or 2 smaller ones.... if one big catalytic converter should have 2 possibly 3 hO2 sensors and if you have 2 smaller catalytic converters you should have 4 hO2 sensors.... to take them out you want your exhaust plenty warm cuz things expand and is easier to remove them. before catalyst is your upstream which helps with fuel delivery and after is your downstream whichs monitors catalyst function. ford uses hO2 sensors which is heated O2 sensors. hope this can help you
Oct 22, 2011 | 1997 Ford Explorer AWD
How to repair the p1646
Looks like Lambda sensor fault,
Fault Code:- P1646 Indicates a Power-train fault
The fault is generally due to a problem in the Computer & Output Circuit area
Fault Description: ECM HO2 Sensor control malfunction -bank 1 upstream (1/1)
Action of ECM:- ECM Default:- HO1S 1/1 control circuit inhibited
After clearing the DTC, complete the Drive vehicle for 10 minutes
Check for a reoccurrence of fault DTC.
Possible Fault:- HO2 Sensor 1/1 heater failure HO2 Sensor 1/1 sensing circuit: short circuit to ground, short circuit to high voltage, open circuit ECM Failure
See http://www.bluejag.co.uk for more info
Aug 30, 2011 | 2002 Jaguar X-Type
1995 Cadi SLS Codes, P0030 & P0036, Ckt Fuse or Relay Defective, checked fuse ok, where is relay located?
P0030 = HO2S Heater Control Circuit (Bank 1 Sensor 1) - No.1 Heated Oxygen sensor on bank 1.
P0036 = HO2S Heater Control Circuit (Bank 1 Sensor 2) - No. 2 Heated Oxygen sensor on bank 1
For both of these to trigger on the same bank, means most likely an Open or Short to Ground condition (somewhere on the Bank 1 circuit) stopping the HO2 sensors from reaching their working temperature.
Check the following in this order:
1) Using a multimeter, check 'continuity' of the Oxygen circuit FUSE terminals (don't rely on visual inspection alone) or replace fuse with a known good one.
2) Check for moisture getting into both oxygen sensor connector terminals (bank 1).
3) Check for good connection at Oxygen sensors (bank 1).
3) Have both heated oxygen sensors on Bank 1 tested (ensure their values are to specification).
4) Check HO2 pin-outs of the PCM for correct voltage.
Only replace the HO2 sensors as a last resort (if out of spec).
Then engine department relay centre & fusebox location is behind the washer bottle, but I believe the HO2 sensors are connected direct to the PCM, not a relay.
Cheers,
"If this has helped you in any way, please rate this solution"
May 07, 2011 | Cadillac Seville Cars & Trucks
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
I have a 2005 GMC Savana G3500 and I need to know how many O2 sensors there are and where they are. Can anyone help?
Oxygen Sensor
CAUTION
The oxygen sensor in-line connector and
louvered end must be kept clear of grease, dirt or other contaminants. Avoid
using cleaning solvents of any type. DO NOT drop or roughly handle the oxygen
sensor.
The oxygen sensor may be difficult to remove when the engine
temperature is less than 48°C (120°F)
NOTE: Removal of the oxygen sensor is
easier when the engine temperature is above 48°C (120°F).
Upstream HO2S Sensor
To Remove:
  1. Before servicing the vehicle refer to the Cautions and
    Warnings at the beginning of this section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    • Electrical harness connector (A) from the HO2 S.
    • Remove the HO2 S (B) using special service tool
      J39194-B.
To Install:
CAUTION
GM uses a special anti-seize compound on the
HO2S threads. The compound consists of liquid graphite and glass
beads. The graphite tends to burn away but the glass beads remain easing sensor
removal. New or service replacement sensors have the anti-seize compound already
applied to the threads. If the sensor is removed from an exhaust component and
if for any reason the sensor is to be reinstalled the threads must have
anti-seize compound applied before installation.
  1. Coat the HO2 S threads with GM P/N 5613695
    high-temperature anti-seize compound as needed.
  2. Install the HO2 S using special service tool
    J39194-B;
    • Torque to 31 ft-lbs (42 Nm).
  3. Connect the HO2 S electrical harness connector.
  4. Lower the vehicle to the ground.
Downstream HO2S Sensor
To Remove:
    • Electrical harness connector (A) from the HO2S.
      J39194-B.
To Install:
CAUTION
    J39194-B;
Sep 23, 2010 | 2005 GMC Savana
The DVD player doesn't work. The service code HO2
I keep having h20 come up on my dvd play er what does that mean it want play
Jun 04, 2010 | Panasonic sa-ht800V Home Theater Audio...
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Panasonic DVD-LS50 Portable DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
