Question about Kenmore 13863 Stainless Steel Dishwasher
Our Dishwasher Model 13863, has the normal wash button continuously blinking. We are unable to reset it even with turning on and off the circuit breaker. It had worked fine up to this point. When you hit cancel drain button it just starts blinking as well
catriver
  • 878 Answers
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
SOURCE: Whirlpool Quiet Partner II
Thank you so much!!! heated dry & hi temp buttons worked!!
Posted on Feb 13, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: WHIRPOOL DISHWASHER WILL NOT DRAIN
I had this problem too & found the discharge hose was clogged. To fix it I had to pull out the diswasher , disconnect the drain hose and blow it out.
Posted on Oct 05, 2008
  • 338 Answers
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Posted on Nov 25, 2008
Normal wash light is blinking but, won't start
Hello friend, thank you for your post!
From the information you have provided regarding the heated dry and washing lights blinking on your Electrolux dishwasher it sounds like it could be a possible problem within your control board. I would recommend resetting your appliance which you can by flipping the household circuit breaker in the off position for roughly ten minutes. If you continue to receive the blinking lights I would reach out to a professional to come and diagnose your appliance. I hope this helps. -Matt
Aug 12, 2014 | Electrolux Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore Elite Dishwasher 13863 will not start
I would check the door interlock, an electrical switch that prevents the dishwasher from running whenever the door is open. Maybe a loose wire there.
Feb 25, 2007 | Kenmore 13863 Stainless Steel Dishwasher
Dishwashers Logo
23 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
