Question about Singer Sewing Machines
Spool thread not being picked up, so machine not sewing
  • 24 Answers
Check to make sure your needle is inserted the proper way and that your bobbin is all the way in and turning when you turn the needle.
Posted on Mar 16, 2011
The top thread will not pick up the spool thread
top thread tension not tight enough
Jul 12, 2017 | Sewing Machines
The top thread will not pick up the spool thread The machine is 801 electronic
Try a brand new needle. Also, verify it is threaded correctly. If that doesn't work, then it is possible the machine is out of time. Search for sewing machine timing or take it for service.
Singer quantum XL-150 how do i thread this machine?
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
Dec 24, 2013 | Singer Quantum XL-1000 Computerized Sewing...
My top thread is not picking up from the spool
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is not warped or damaged
also make sure the bobbin case is not damaged
if these suggestion don't help then it would be a good idea to have the
machine checked at a sewing machine shop to see what is wrong with it
May 31, 2012 | Sewing Machines
I seem to be threading the spool correctly, yet the needle doesn't pick up the thread.
You haven't stated the exact model, but the principle for picking up the spool thread is pretty universal.
After loading the spool into the bobbin case and correctly threading the spool, pull the thread up through the sliding cover plate to lie on the machine bed and mostly close the cover.
Lift the presser foot, thread the needle and then advance the balance wheel slowly so that the needle goes down and then returns up. If the machine is correctly threaded, correctly adjusted , has an unbent needle and the needle is appropriate to the thread size, then it should pick up the bobbin thread. Just pull on the loose end of the needle thread and the loop with the bobbin thread should come up through the needle hole. Pull both threads to the right from where they have just emerged, allowing the loose end of the bobbin thread to disappear beneath the cover plate before re-emerging through the needle hole. Close the cover fully, lower the foot onto the work and start sewing.
If the above fails, then check that the spool is loaded the correct way around into the bobbin. It makes no difference to many models, but does to some. If you don't have the instruction book then just try both ways. It also helps to ensure that the machine is correctly maintained with no build ups of lint and correctly oiled with sewing machine oil. This is a light oil grade but has additives to ensure that it sticks where it's needed, "3-in-1" brand oil can be used but may need to be applied more frequently and the machine will need cleaning more often.
If the pick up still doesn't work, then your machine needs to go for repair as it either has a damaged bobbin or a screw has come loose in the mechanism causing the machine to lose timing. For older Singer models, all of the timing and servicing information is available free on the web. Just enter your model number followed by "manual" or "service".
Good luck, please add a comment if any of my answer has puzzled you, but otherwise I'd appreciate it if you would take a moment to rate my reply.
Sep 17, 2010 | Singer Sewing Machines
Tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
May 15, 2009 | Baby Lock BL1556
The needle does not pick up the bobbin thread
Hi!
There may be so many reasons due to which the needle does not pick up the bobbing thread like---
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Machine problem
Hi!
There are so many reasons due to which the thread is not picking up from the bobbin like:
The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
The needle could be threaded incorrectly. Thread the needle eye from the front to the back.
Do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Bernina Activa 130
Brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Oct 21, 2008 | Brother LS-1217 Mechanical Sewing Machine
Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
Aug 25, 2008 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
