Need to move a 57"
  • 604 Answers
Stand the tv on its end so it can go around the corner
Posted on Mar 16, 2011
How to set the points on a 1973 yamaha lt2 100
I do not know what the dwell or correct gap would;d be to get the correct dwell so I cannot help that way. You will need to google it or get the gap and/or dwell from a Yamaha or other such service center. To change point gap normally there is a screw which will loosen and allow the points to be moved (one side of the point assembly) so that with the cam that moves the point assembly apart on the middle of the high point the points can be set with the required gap between the open points to give the required dwell for coil primary saturation.,
Nov 27, 2014 | Yamaha Motorcycles
We live in an apartment that provides a GE Stackable Washer/Dryer unit. No matter how we fill it (1/4, 1/2 or full), it rocks out of control and bangs loudly on the spin cycle. Our maintenance people...
Absolutely!!! ( Not impressed by your 'maintenance people')
Start here-
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | Washing Machines
The "Video 1" in the upper left corner of the
Press the "display" button on the remote until all displays are gone.
Jan 24, 2011 | Sony KP-57WS500 57" Rear Projection...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can I remove the base to this TV to move it?
Yes the set can be disassembled and then reassembled. But you would need the service manual that will explain how to get the set apart into seperate pieces. Heres a link to where you can get the service manual for your model they send it by download link.
http://servicemanuals.vstore.ca/product_info.php/pName/av65wp74/cName/jvc
Jun 15, 2009 | JVC AV-65WP74 Rear Projection Television
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
Tread will not move, shows a L 5 error code
You need a new lower control board. 225.00 from nautilus.
Dec 14, 2008 | Bowflex Treadmill Series 7
Cabinet removal
Unfortunatly no there isnt. The tv bottom contains all the circuits, color guns, speakers. From where the bottom of the screen starts to the top is all part of the entire cabinet which is molded plastic. The top part contains a mirror and the screen you see as well as possibly a remote sensor. Short of sawing it in half and tossing it away you could take it apart but this would have to be done completely to gain you the most space and could be dangerous considering the high voltage transformer that the unit uses to power the color guns.
Mar 07, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Need to take top half of hitachi off and move through tight door way in basement
I suspect not especially if the speakers are in the bottom half. And not if the chassis is in the bottom half
Dec 22, 2007 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
