Question about NEC (NWL-100A) 802.11g/b Wireless Adapter
I have a nec LT265 projector and to connect wirelessly i need this wireless card that fits into the pc card slot to get connected. I was thinking about just buying a wireless stick and connecting via the usb port, is this possiable or will the connection be super slow. and if i do buy the NWL 100 card will i be able to use it with my macbook? thanks for the help
SOURCE: XP won't boot with NEC SD-V2-5U USB card installed
Have you tried moving the card to a different slot? The motherboard BIOS and/or the operating system may be trying to assign an interrupt that cannot be shared--especially if you have the card installed in the slot next to the video card (or shared with the onboard video).
Posted on Nov 07, 2007
SOURCE: critical error 678
plug usb connector into back of computer (not front)-worked for me.
Posted on Jun 20, 2008
  • 8 Answers
SOURCE: NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip In addition, you should make sure that you have Activesync 3.8 or older. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Posted on Dec 30, 2008
SOURCE: wireless switch
hi i had the same problem press fn and f2 at the same time keep held in for a couple of secs that will fix it regards **** best leeds
Posted on Feb 08, 2009
SOURCE: Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Posted on Mar 31, 2009
Is there any way to connect to wireless internet with this kind of computer or whether need to other hardware .thank you.best regards.
The easiest way to connect to a wireless internet connection is to purchase a wireless networking card that fits in the PCMCIA slot. I would recommend a Linksys Adapter (WPC54G).
Jun 21, 2011 | Compaq Armada M300 Notebook
How to reset lamp hours lt265 nec
Select the Menu [Reset] → [Clear Lamp Hour Meter] to clear the Remaining Lamp Time and the Lamp Hour Meter
Mar 05, 2011 | NEC LT265 Multimedia Projector
The lens projector was pushed in and does not turn enough to adjust the focus.
hello therese prof, Hi, the lens is out of alignment, this could be aligned by disassembling the unit up to only on the outer part. of the case. once the cover is removed, you can re align the focus lens. no need to totally dismantle the entire unit. the lens is a separate passive device not connected to the electronics board.
Mar 03, 2011 | NEC LT265 Multimedia Projector
NEC LT265 PROJECTOR WILL POWER UP BUT WILL NOT COME ON. BULB IS A YEAR OLD. WAS PLAYING A MOVIE WHEN IT WENT OFF AND WILL NOT COME BACK ON. NOR WIL THE FAN RUN. POSSIBLE BALLAST?
It cannot be a ballast because the fan would not run off a ballast. Sounds like a serious hardware failure, I would check with the manufacturer.
Mar 10, 2010 | NEC LT265 Multimedia Projector
How is the T42 adapted to make it wireless?
you can buy an expansion wireless card. there are models ranging from "B" standard to "N". look for the one that fits best your needs and don't leave the usb wireless connection devices unchecked, they may be cheaper than the expansion cards, but they may get the hold of one or 2 usb slots. but this model of laptop generally comes with an integrated wireless connection device. if it's broken, and you don't have an expansion slot, you'll have to get the usb models.
Feb 06, 2010 | IBM ThinkPad T42 Notebook
Make my Compaq Presario Laptop Wi-Fi.
If the wireless card is about the size of a thick credit card then it is a PCMCIA card device. This card plugs into the PCMCIA slot on either the LH side or the RH side of the laptop. You need to install the wireless card driver on the laptop and configure it to communicate with your wireless router which is connected to your Internet Service Provider. This wireless card can also connect to the Internet on free WiFi sites. As you are a novice, you will need a computer savy friend to help you or your friendly computer shop.
Jun 10, 2009 | Compaq Computers & Internet
Has An Acer Travelmate 243LC laptop got a build-in Wireless?
The link below will take you to a page on the Acer Web site that shows the specs for this laptop. According to the specs, this laptop does not come with onboard wireless (if this feature were part of the system, it would be listed in the specs). Also, you can check Device Manager to see if you have a Wireless Adapter listed under Network Adapters. If you don't see any type of Wireless adapter listed then you'll definitely know that your laptop doesn't have it built in.
To access Device Manager:
Right-click My Computer
Click Properties
Click Manage
In the left navigation pane, click Device Manager.
In the larger window, scroll down the list to Network Adapters.
Expand the Network Adapters tree to see the installed adapters.
http://www.acersupport.com/notebook/html/tm243lc_specs.html
However, the specs do show that this laptop has 2 PC Card slots. These slots give you at least a couple of options for connecting to the Internet. You can buy an Air Card that is installed in one of the PC Card slots when you want to use it to access the Internet. My company used to provide Air Cards for laptop users through AT&T. The advantage is that you have an uninterrupted connection to the Internet no matter your location.
You can also buy a WiFi card that fits into a PC Card slot. This card will be your Wireless NIC (adapter) providing you with the means to set up connections to wireless networks. Linksys is a pretty good brand and fairly easy to install and support. After installation and configuration, you can pop the card in your PC Card slot anytime you want to connect to a Wireless network then remove it when it's no longer needed.
I hope this helps you connect wirelessly using your laptop. Please rate this solution and thanks for using Fixya.
Mar 28, 2009 | Acer TravelMate 243LC Notebook
Mar 23, 2009 | NEC VT676 Multimedia Projector
NEC Versa FX
The phone jack does not fit because it is an RJ45 network port. If you are using a cable modem or router for your dsl connection you should be able to connect directly with a cat5 network cable.
Or if you have a free USB port you can purchase a wireless adapter like THIS ONE and use it via the USB port.
Nov 15, 2008 | NEC Versa VX Notebook
NEC (NWL-100A) 802.11g/b Wireless Adapter Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
