Question about RTO Wiggy 6610VT1 Voltage Tester
I have a wiggy 6610 VT-15 voltage tester. I have a broken fuse but can not locate one at any hardware stores. Do you have any suggestions.
    Sergeant:
    Champion:
  • 250 Answers
I would try radioshack. They should have those shorter thinner fuses.
Posted on Mar 16, 2011
No power to rear blinkers
Instead of being a H-D ick like you know who I would suggest that you start by checking your bulbs for resistance. Sometimes they look okay but the thin filament inside may be broken. If the front turn signals work, then your rear signals should work, so your push button and Flasher is okay. Check the wiring at the bulbs for voltage. Test the bulbs as you depress the turn signal button. Use the metal of the bulbs base for ground and check the other wire for voltage, if there is no voltage, you may have a bad ground at the base so attach the ground to the batteries ground. Still no voltage? Most likely there is an issue with the wiring towards the rear where the harness connects the positive line from the Flasher. If there is some voltage at the bulbs (assuming your battery is fully charged) then be sure to check for corrosion on the inside of the turn signals base and also where the ground wire terminates at the frame. Next, locate the wiring harness lighting circuit for voltage. There may be a break in the line leading to the bulb. There are 12 volt 'wiggies' that will help you locate a break in an electrical line.
Apr 10, 2015 | Power Motorcycles
Put something to heatup after pushing start made standard startup noise then abruptly stopped working even electronics....breaker fine and receptacle working....does this unit have a fuse??
Almost all microwaves have internal fuses. Counter top micros need to remove outer case and fuse should be near where power cord enters the microwave, Fuse looks like old style glass car fuses but is white or gray ceramic. Can't look at it to tell if its bad. Need tester. Over the range (wall Micros) usually have the fuse directly behind the control panel which you will need to drop down away from the body. Same type fuse as stated before. 15 or 20 amp should be stamped on metal edge. Purchase at Radio Shack or a parts store---or some Hardware stores.
Mar 31, 2015 | Microwave Ovens
Is there a fuse for the horn on a 2000 Chevy Malibu?
fuse for horn on a 2001 malibu is located under the hood.
there is a fuse (15 amp) in slot #43
and there is a relay in slot #21
if you remove the relay and put it back in wrong the horn will not work.
Sep 26, 2014 | 2000 Chevrolet Malibu
I need an instruction manual for a Klein 69100 voltage tester
Try
mauritron2.com
They have a good range of
Technical Repair Service Manuals
and
Owners User Instructions Operating Guides
I've used them in the past with good results.
They even managed to get a guide for me which was not shown on their site
Jul 25, 2011 | Klein Electronics Klein 69115 Wiggy...
How do you check an alternator or a voltage regulator on a1990 ford F250 diesel.
Here is a easy way to do it have a voltage tester on hand///multi meter put the positive to positive and negative to negative you should have engine running your voltage reading should be 12.79 up to 14.29 anything under bad alternator anything over 14.29 is bad that's over charge that usually cooks the battery.And truck not runnig test the battery same fashion your reading should be 12.79 up to 13.29 is good under battery no good.Good luck to you
Jan 31, 2011 | Ford F-250 Cars & Trucks
Do you know where we can purchase a Wiggy Square D 6610 voltage tester?
Go to this page and click on "find a retailer":
http://www.service.kleintools.com/Tools/PRD/Category/Continuity%20Tester%20TESTERS-CONTINTEST-CONTTEST/Product/69115
I should tell you, as an electrician, the Wiggy is considered obsolete. The Klein ET200 will do the same thing as a Wiggy and also tests continuity. When the leads are placed in the tester's built-in grooves you can easily test tamper-resistant (TR) receptacles:
http://www.homedepot.com/Electrical-Electrical-Tools-Accessories-Electrical-Test-Meters/h_d1/N-5yc1vZ1xg4Zboff/R-202266608/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Dec 10, 2010 | Your One Source Square D Wiggly Voltage...
Can I test a 12v battery
My friend ... here is the answer:
Description:
  • WIGGLY VOLTAGE TESTER
  • Solenoid type tester polarity
  • indicator
  • 120/240/600 VAC; 50/60 HZ
  • Lifetime warranty
Your 12 volt battery is DC voltage as well as far below the voltage testing threshold of 120 volts.
Thank you for your interest n FixYa.com
Jan 13, 2010 | Your One Source Square D Wiggly Voltage...
How do you get the contact tips together so that they work. It is a 6610 wiggy tester.
To check your meter for continuity, put settings on dial to the Ohm setting. Touch the 2 tips together & if it is operating properly, the needle will spike. Then you can check a circuit on a wire using both tips to touch (black) wire & (white) wire.
Sep 28, 2009 | RTO Wiggy 6610VT1 Voltage Tester
Fuel pump quit working,I replaced fuel pump relay,nothing...cant find location of "ECM BAT" fuse,and the fuel pump relay connector. My chilton manual does'nt show
Have you checked the fuse box under the driverside dash? If memory serves it should be a 15 to 25 amp fuse. I would suggest you check all of the fuses with a fuse tester. And take a close look at all the grounds.
Aug 20, 2009 | 1994 Chevrolet S-10 Blazer
I have a bad circuit (S type 15 amps fuse) that blows every fuse I put in it. My four way voltage tester says that it runs at 110 volts. Does this mean that I have a ground or short circuit problem? If so,...
please describe what type of device or circuitry you are having the fuse repeatedly blow so that I have a better idea of understanding your specific circumstance. A constant blown fuse normally indicates a short somewhere or an overloaded circuit somewhere. The type of tester you need is a ground fault receptacle tester you can purchase them at any hardware/electrical supply store for between $10-15 that tester when plugged in will show whether you wiring is correctly installed or not. please respond with further info and I can be of more assistance
Aug 04, 2009 | Gb Electrical GET-213A Heavy-Duty 4-Way...
RTO Wiggy 6610VT1 Voltage Tester Logo
186 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
