Question about Sony Gran Turismo 5 for PlayStation 3
I had my PS3 hooked up to an HDTV for awhile and then along the way I had to move back to normal 480i video output settings as my TV is no longer up and running due to catastrophic failure in which we'll leave at that. Anyways all my other games work and the video settings for them were reset but now when I run Gran Turismo 5 the video settings are still in the HD resolution and everything is hard to see... What do I do?... HELP!!!
  • 51 Answers
Do the three beep hold the power button dowen
Posted on Apr 11, 2011
Trying to hook up a playstation 2 to a sylvania LC195SLX tv
The PlayStation 2 may natively output video resolutions on SDTV and HDTV from 480i to 480p while other games, such as Gran Turismo 4 and Tourist Trophy are known to support upscaled 1080i resolution using any of the following standards: composite video(480i), S-Video(480i), RGB(480i/p,
Which output from the game to the TV are you using?
Apr 13, 2014 | Sylvania Televison & Video
I have the cables hooked up between my PS3 and to the DTV connectors on the back of my Mitsubishi WS65809, but the display is still in 480i. What do I have to do to get 1080i?
In the Main menu screen for the playstation, navigate to Settings, - Display settings -Video Output Settings Press X to select It will ask what type of connector on your TV, choose component/D-Terminal press x to continue it will ask to select a setting mode, you can choose automatic or custom, Choose custom, x to continue you should be given a list of resolutions, check all those that you want to work up to 1080i (1080p is only on HDMI) press X to continue, follow instructions to finish setup,
Mar 31, 2011 | Eforcity HD Component Cable for PS2...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How do i use the ps3 on a normal tv
If the "normal" tv has the Composite(rca) inputs yellow red and white. the PS3 will work on that if it doesnt you can buy an RF mudulater for under $20 at Walmart. When you do hook it up to those input you next have switch the channel to the input. Also the video settings on the PS3 have to be set for 480i no other setting works on a "normal" tv
Dec 14, 2010 | Video Game Consoles & Games
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Switching our ps3 from hd to normal
with only the PS3 and the TV connected, touch and hold the systems’ power button for more than 5 seconds to switch the system back on. The video output settings will automatically be reset to the standard resolution
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Playing on a regular TV.
Ensure you have returned the PS3 video output system setting to 480i vs the 720/1080 setting. Regular TV will give you a black screen at the higher resolutions.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3
You need to reset your video settings when you move to a regular TV. Just hold down the power button, it will beep twice and go back to stand by mode. They boot up again and your video setting should be back to normal ( for standard TV).
Bimmerhp
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
OUTPUTS DONT WORK?
hook it back up to the HDTV and get into the menus. Get into the video menu and make sure that it is NOT set for progressive scan (normal TV's are Interlace).
Sep 12, 2007 | Sony Playstation 3 (PS3) Console
Sony Gran Turismo 5 for PlayStation 3 Logo
130 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
