Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Will not idle, when i give it gas it boggs down. does air filter need cleaned? if so where is it located.
  • 784 Answers
Remowe top cap and under this cap you will see it. clean it with gasolin let dry.
Posted on Mar 16, 2011
1996 GMC SUBURAN. It starts idels ruff. when giving gas or accelerate, it boggs down. no power
The basics for a rough idle, check for a leak of some kind, fuel--egr--vac leak. As far as idle, you can check and clean idle air system.
The basics for problems at higher rpms, check for a blockage of some kind, fuel--air--exhaust.
How long since a tune-up? Any applicable trouble codes?
Oct 13, 2017 | GMC Cars & Trucks
Idles but Boggs down when u give it gas
Hi Anonymous, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
May 31, 2012 | Harley Davidson FXD Dyna Super Glide...
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
if it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Dec 11, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Goes bad when you give it trottle
If your bike boggs down when you attempt to accelerate, it usually indicates that it is starving for fuel. It could be many things..an inline filter, trash in a jet, a stopped up strainer in the gas tank, excessive plaque in the carb. You can try some simple fixes such as replacing an inline filter, (if you have one). But usually the fix will involve removing the carb and soaking it in carb cleaner, replacing seals, gaskets, blowing out the jets, cleaning or replacing the lines. If your bike idles ok, but when you throttle up it boggs, you are getting enough fuel to make it idle, but not enough to accelerate, so when you call for more fuel, (accelerate), and it can't get it, the mixture leans out, (has too much air and not enough fuel). Hopw this is helpful. Good Luck!
Oct 23, 2009 | Honda XL 125 R Motorcycles
Yamaha blaster 240cc
the mechanic should adjust the idle of the fuel pump because.I think there are much gas that is going to the engine.and also check the air filter if there are dirt on the filter then replace filter .for sometimes it can be the exhaust.
Aug 11, 2009 | 2003 Yamaha YZ 125
04 exc 450 wont rev
Pull the slide and move the jet needle clip down 1 or 2 notches.
Apr 21, 2009 | 2004 KTM EXC 450 Racing
SUNL 50CC SCOOTER
You may need to adjust the fuel/air ratio. There is a small screw under the pull starter facing horizontally (its behind the plastic air filter cover, but accessable) adjust either clockwise or counter clockwise in small increments and give it gas and see if it dies or boggs down. Also check that spark plug is clean and not fouled, and air filter is clean and oiled.
Jul 24, 2008 | Transport Schwinn Rechargeable Portable ...
50cc Sunl gas scooter
You may need to adjust the fuel/air ratio. There is a small screw under the pull starter facing horizontally (its behind the plastic air filter cover, but accessable) adjust either clockwise or counter clockwise in small increments and give it gas and see if it dies or boggs down. Also check that spark plug is clean and not fouled, and air filter is clean and olied.
Jul 06, 2008 | Transport Schwinn Rechargeable Portable ...
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
