Question about Neff 24 in. S5443X2 Built-in Dishwasher
Pump keeps running after washing finished - Neff 24 in. S5443X2 Built-in Dishwasher
  1. WATER ON BASE OF D/W FROM LEAK
Posted on Aug 10, 2008
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
Keeps saying F21 and will not finish washing
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pump keeps running after cycle has finished
you have almost certainly got a leak in the sump(bottom) of the unit. The limit has been activated thus switching the drain pump on continuously untill it is rectified. Mostly the main wash motor has the leak. Order and replace.
Sep 15, 2009 | Bosch Dishwashers
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
May 14, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washer will not spin properly on a Kenmore 110 23812100
your pump is partially clogged or your drain hose is kinked
Dec 09, 2008 | Kenmore 23822 Top Load Washer
The wash liquid does not empty after the wash is finished
hi, it sound like your waste outletis obstructed or the pump is not working, to empty the machine pull the easte pipe out of the stand pipe ,get a bowl, keep the pipe above the level of the drum! slowly lower pipe into bowl the water should run from the machine to stop the flow lift the pipe above the drum level, continue until machine empty! if the MACHINE EMPTIES THIS WAY THERE WILL NOT BE A BLOCKAGE AND YOU SHOULD CHANGE THE PUMP, hope this helps you
Nov 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Neff 24 in. S5443X2 Built-in Dishwasher Logo
166 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
