As i try to turn on amplifier its automatically swithing itself off.(within a second)
  • ed1974 Mar 18, 2011
    as soon as the power button is pressed it immediately turns off.sometimes long enough to see display(momentarally)but doesnt stay on long enough to listen to any sound.when power button is pressed to the time you take your finger away,we are talking milliseconds.
    the machine is a technics separates system,the model is:DV290.and the amplifier is sadv290.
  • 26 Answers
Your amplifier is in a protect mode due to an internal malfunction.
A flashing light code could state what the problem is.
There could also be an internal blown fuse.
Posted on Mar 16, 2011
  • ed1974 Mar 16, 2011
    it now and then flashes up f 61.and if i hold in the main on button on front of hi-fi,and press various buttons(input selector/settime/band)it tries to start even the fan can be heard starting up momentarally.internal fuse is good continity checked.relay works can be heard switching.im at a complete loss??
  • ShootDanger Mar 17, 2011
    With more information as to what type of amp it is, the error code "f 61" could be referenced to what the problem is.
    If holding the power button in allows the unit to function, and then releasing the power button causes the unit to power off, the problem could be in your power switch. It could simply be not keeping a connection when depressed. Does the amp function at all (make sound) when the power button is depressed?
My DSL 2730 U ADSL router is getting switched off automatically within seconds, it powered on. No other LED's turning on. Can anyone help to resolve the issue.
I would try a factory reset. If the router is physically powering itself off chances are you have defective router.
Aug 04, 2016 | Computers & Internet
My digital amplifier S-MASTER,mod HDC-SB300 just 5 seconds after I turn it on swithes off by itself and the standby light keeps flashing and the display stays off and i can do nothing..thanks
hi,
may be ur amplifiers any of the output channel have some problem. that's why it goes off after power on, protecting ur speakers. disconnect all the speakers and inputs and then power on it if works check ur speakers and inputs. if not there is fault inside ur amplifier.
ok
Dec 22, 2010 | Sony TA-N9000ES 5-Channel Amplifier
Hi my amp when i switch it on within 3 seconds it automatically switches off?
HI...
That's the protect circuit kicking in.
The rec'r will require service. Either a couple of power supply capacitors have gone bad or one of the power amp modules has quit.
Nov 02, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Turn on and it turns off by itself within a second
try to charge it maybe its low battery
Mar 07, 2010 | Nintendo DS Lite
Every time i hook up my coustic car amp the radio will turn on with out the radio on
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RADIO OR AMPLIFIER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL POWERS UP ON ITS OWN, THEN REMOVE THE REMOTE TERMINAL COMING FROM THE RADIO. IF THE AMPLIFIER SHUTS OFF, THEN YOU MAY HAVE A SHORTED TURN-ON TRANSISTOR WITHIN THE RADIO AND IT IS OUTPUTTING THE DC NEEDED TO TURN THE AMPLIFIER ON. IF YOU REMOVE THE REMOTE TURN-ON FROM THE RADIO TO THE AMPLIFIER AND THE AMPLIFIER STAYS ON, THEN THIS POINTS TO A FAULT WITHIN THE AMPLIFIER AND IT WILL NEED TO BE SERVICED. MAKES SURE THAT THE AMPLIFIER AND RADIO GROUNDS ARE 100%. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 15, 2010 | Coustic Car Audio 401SE Car Audio...
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
My amplifier
The "switched off by itself" is indicative that the auto-protect is acting. Auto protect senses that there is something wrong within the unit and rather than the damage extend to other areas, it simply switches the entire unit off. On some models, this also hold true if there are no or faulty speakers connected to the receiver. In others, this happens when there is no intelligent signal received such as in FM when an antenna would be required.
If you have verified that it is not poor signal, speaker problem, then perhaps your best bet would be to seek the services of a qualified audio technician since this would involve electronic circuitry/component diagnosis, soldering and the use of a DVM.
hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Audio Players & Recorders
TEAC Amp
The amp is going into "protect mode". This means there is a bad part or parts being detected. Professional service will be needed.
Sep 13, 2007 | Teac A-1D 2-Channel Amplifier
Auto-powering off within seconds of turning on
timing out or takeup sensor faulty located next to carriage
Mar 18, 2007 | Panasonic PV-8661 VHS VCR
301 people viewed this question
 Grubhead
Grubhead
