Question about Broksonic DRVCR900 DVD Recorder/VCR
Can I recored a VCR to the DVD on this machine?without a TV?
    President:
  • 1,285 Answers
Yes, but I strongly suggest you use the screen (unless the recording is a 5 - 6 hour epic) where as you record the event and go to sleep and the devices shut off once finish.
Posted on Mar 16, 2011
Manual recording procedure
I am assuming that is what they ment.
Because a DVD Player would not be able to Recored anything at all. And he did not mention anything about there being a VCR in it or anything about a VCR in Fact.
You would have to Have a DVD Recorder to Record anything onto DVD's
Aug 24, 2012 | Panasonic DMR-E85H DVD Recorder
My drv/vcr recorder wont record,i'v tried several dvd's and it wont read them it keeop saying it cant be recored on
Most dvd/VCR combo's dont record to DVD but record from the DVD to the VCR. If yours doesnt say DVDR DVDRW+ or DVDRW- then it doesnt write to DVD.
Apr 17, 2010 | Televison & Video
In idiot terms how do i connect a tv with 3 scart sockets to a dvd with 1 socket a vcr with 2 sockets and freeview with 2 sockets so i can watch and recors both tv and freeview, a diagram if available...
you need a multi scart lead accessory pack from an electrical outlet like currys. they pack has a wiring/connection diagram on the reverse of the pack.
Oct 24, 2009 | Televison & Video
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Iput dis in to recore itsaid cannot record c206
Try a DVD-R or DVD-RW that are only are for 2X speed and no faster.
Feb 07, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
DTA800B1 how or should I say why can I not see channels on the VCR when the converter is hooked up to it and the tv works just fine but will not set the channels on the vcr
instead of putting the converter box on ch4 ,put it on ch3 same as the vcr . set the converter box channel for the channel to be recorded, program the vcr to channel 3 for the channel to be recored. set the time and date on the vcr progam.tv does not need to be on for the program to be recored but the converter box needs to be on.
Aug 21, 2008 | RCA Televison & Video
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Jun 03, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Broksonic DRVCR900 DVD Recorder/VCR Logo
140 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
