90 kg is = to how many lbs - Office Equipment & Supplies
    President:
  • 2,080 Answers
1 kilogram = 2.20462262 pounds,
Therefore 90 Kg = 198.416 pounds.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Posted on Mar 16, 2011
How many lbs are 105.9 kg?
Hello;
My name is Peter. I am a engineering college graduate.
Kg x 2.20462 = Lbs. or 105.9 Kg. x 2.20462 = 233.5 Lbs.
Mar 13, 2015 | Cars & Trucks
Conversion from kg to lb
Multiply by 2.2 to get lbs. In this case, 84 kg should convert to approximately 184.8 lbs.
Aug 19, 2014 | Cars & Trucks
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
Dec 05, 2013 | Office Equipment & Supplies
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
I need to find the torque specs for the connecting piston rod? also the sequence and torque for the cylinder head bolts this is for a kia rio 2004 6cyl
22 - 24 ft. lbs. for the rod caps and....
110795143Cylinder Head Tightening Torque and Sequence.
Tighten cylinder head bolts in order shown.
Tightening torque: 36.1 ft. lbs. (49 Nm, 5 kg-m)
Loosen bolts in reverse of order shown.
Retighten cylinder head bolts in order shown.
Tightening torque: 18 ft. lbs. (25 Nm, 2.5 kg-m)
Mark cylinder head bolts for rotational reference.
Rotate cylinder head bolts 90°(1/4 Turn) in order shown.
CAUTION:
  • Do not reuse the old cylinder head bolts.
May 31, 2010 | 2004 Kia Rio
How to convert from kg to lbs on the defrost cycle
.45 kg = 1 lb
2.22 lbs = 1kg
So if you know kg and need lbs. multiply the number of kg by 2.22. for example if you have 4 kg
4 x 2.22 = 8 lbs
May 10, 2010 | Panasonic NN-H275 Microwave Oven
How do you change the weight settings from kg to lbs
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Mar 08, 2009 | Nintendo Wii Fit for Wii
What are the torque settings for the cylinder head 2000 subaru forester
This procedure is for the SOHC only.
E: INSTALLATION
1. CYLINDER HEAD
  1. Install cylinder head and gaskets on cylinder block. CAUTION: Use new cylinder head gaskets.
  2. Tighten cylinder head bolts.
  1. Apply a coat of engine oil to washers and bolt threads.
  2. Tighten all bolts to 29 Nm (3.0 kg-m, 22 ft. lbs.) in alphabetical sequence. Then tighten all bolts to 69 Nm (7.0 kg-m, 51 ft. lbs.) in alphabetical sequence.
  3. Back off all bolts by 180° first; back them off by 180° again.
  4. Tighten bolts (a) and (b) to 34 Nm (3.5 kg-m, 25 ft. lbs.) .
  5. Tighten bolts (c), (d), (e) and (f) to 15 Nm (1.5 kg-m, 11 ft. lbs.) .
  6. Tighten all bolts by 80 to 90° in alphabetical sequence. CAUTION: Do not tighten bolts more than 90°.
  1. Further tighten all bolts by 80 to 90° in alphabetical sequence shown in figure provided. CAUTION: Ensure that the total "re-tightening angle" [in the former two steps], do not exceed 180°.
May 24, 2008 | 2000 Subaru Forester
51 people viewed this question
jasbo
jasbo
