Question about Dryers
My dryer heat but tub want turn i open the back and the belt was laying on the floor on the rt. side i would like to know if i would be able to replace it or not.
  • Kelly
    Kelly Mar 16, 2011
    HI and welcome to FixYa. I am Kelly. What is your "make and model number" so I can pass instructions and parts information on how you the owner can replace your dryer belt. Without that information I would just be guessing and that would not be professional on my part.
    Thanks,
    Kelly
  • maryloveschr Mar 17, 2011
    serial # m 81823076 model# 86880800 This is from maryloveschrist@aol.com It is a Kenmore easy care
  • Dryers Master
  • 3,740 Answers
Hi again, Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200?searchedModel=86880800&blt=11
The belt is item 30 of this page:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200/00041279/00002?blt=06&prst=&shdMod=
The manual that will help you is here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Removal of the top is on page 19 / 14 printed of the pdf file
Removal of the toe panel is on page 20 / 15 printed if the pdf file
Removal of the front panel in on page 24 / 19 printed of the pdf file
The belt is installed with the ribs against the drom and the udler pulley / motor routing for the belt can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramH
Once you have the drum loose inspect the rear bottom drum rollers and idle pulley for any signs of wear. Flat spots or hard to turn = replace.
Thanks for choosing FixYa,
Kelly
Posted on Mar 17, 2011
Testimonial: "the infro. was very helpful .i will try to put it back together today. i will let you know the results."
Heat won't go on...don't know if it's an ignitor problem, or a coil problem
UNPLUG DRYER REMOVE TWO PHILLIPS SCREWS UNDER FILTER ON TOP LID ....
FLIP TOP TOWARDS WALL REMVOVE 5/16 SCREWS IN TOP CORNER OF CABINET AN LEAVE DOOR AND FRONT CONNECTED REMOVE DRUM BT RELIEV IDLER BELT TENSIONER INFRONT OF MOTOR AND SLIDE BELT AND DRUM OUT OF CABINET AND SET OUT OF WAY TURN DRYER IN TIMED DRYER NEAR 60 AND LAY ON FLOOR INFRONT OF DRYER ON FLOOR INFRONT OF DRYER INFRONT OF BURNER TUBE AND WATCH AND LISTEN IGNITOR SHOULD GLOW RED THEN A CLICK THEN IGNITOR SHOULD LIGHT GAS ..... IGNITOR DOSENT GLOW CHECK WHITE PLASTIC FUSE ... IF IGNITOR GLOWS AND NO CLICK THE REPLACE FLAME SWITCH ALUMINUM AND BLACK BOX ON LEFT SIDE OF BURNER TUBE ...IF CLICKS AND NO GAS REPLACE GAS COILS
Jan 26, 2011 | Estate TEDX640JQ Electric Dryer
I need to replace a belt on my hotpoint dreyer how do i do it
Disconnect power.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screws and raise the top.
Look down inside the open top dryer from above . If unbroken it should be showing across the tub from left to right. If broken you won't see a belt (about 3/8" thick). If belt is missing, proceed. On each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top. Take the new belt and work it over the drum from front by lifting and rotating the drum. Lay belt on drum about 1/2 way back from front with groves down on the drum and proceed to reassemble machine by reversing disassembly procedure.
When reassembling the top, part of each underside edge of the top must go beneath a sheet metal lip located at each right and left edge of the dryer just below the control panel. If the small space between the side and top panels is wider at the back than the front you have not accomplished this alignment, try again.
Once you have the top and front back on, pull out the dryer and remove the small access panel at the back bottom. The belt must be "looped" around the motor and idler pulley like this ( http://www.applianceaid.com/images/ldrger-idler-pulley.jpg ). Slowly turn the drum around one turn to line up the belt, to make sure that it will not fall off because of being crooked or twisted.
Sep 16, 2009 | Hotpoint NWXR473GV Dryer
Motor is running but not turning drum to dry the clothes. We removed the back of dryer to see if maybe belt slipped or broke but can not see any belts and do not want to start removing a lot of screws...
Look from the rear, near the bottom. The belt wraps around the drum, and near the bottom is a tensioner that keeps tension on the belt. If it is broken, you'll see it laying on the floor of the dryer.
Jul 03, 2009 | Estate EED4300TQ Electric Dryer
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Drum doesn't turn in maytag neptune MDE9700AYW
Just remove the screws around the vent tube in the back and you can see the belt tensioner laying there on the floor of the dryer.
Most likely someone turned the drum the wrong direction and the belt came off.
The belt goes through the opening in the tensioner and under the idler pulley and then onto the motor drive pulley. Make sure to have the tensioner mounted into the floor first.
It just slides over into a slot and then over to the other side as tension is put on it.
Jan 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Jan 08, 2009 | GE DBSR453EBWW Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Belt busted
lets see what we can do. wrap the belt around hte tub assy. the little white roller w/ metal arm (called the tension pulley) needs to be installed .there should be a few ****s directly under ther motor pulley on floor of unit.two sets of ****s you wanna use the set to ther rear of unit. insert the prongs into the left rear **** and then pull the roller portion to the right.(it should hook the back prongs of idler into the rt side ****s. tension holds this into position so it will fall out if you let go) theres an opening in the metal under the roller mounts, e**ugh room to slide the belt through.heres how it works, install the idler as described above, feed the belt through the opening in the idler from the left and under roller through hole pull hte roller and pulley hard to the right.(its springy and as long as installed correctly ** worry of popping out) and loop around the motor pulley.let go of the pulley. and the belt should remain tensioned. it will only go on on way. GOOD LUCK
Mar 10, 2008 | Kenmore 63942 Dryer
Belt and tensioner
lets see what we can do. wrap the belt around the tub assy. the little white roller w/ metal arm (called the tension pulley) needs to be installed .there should be a few holes directly under the motor pulley on floor of unit.two sets of holes you wanna use the set to the rear of unit. insert the prongs into the left rear **** and then pull the roller portion to the right.(it should hook the back prongs of idler into the rt side holes. tension holds this into position so it will fall out if you let go) theres an opening in the metal under the roller mounts, e**ugh room to slide the belt through.heres how it works, install the idler as described above, feed the belt through the opening in the idler from the left and under roller through hole pull the roller and pulley hard to the right.(its springy and as long as installed correctly ** worry of popping out) and loop around the motor pulley.let go of the pulley. and the belt should remain tensioned. it will only go on on way. GOOD LUCK
Feb 08, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
165 people viewed this question
Top Dryers Experts
