Question about Kenmore 16522 Built-in Dishwasher
I have a Kenmore Ultra wash 665.16522. The water won't drain completely. About 2 or 3 inches of water will stay at the bottom. I wonder if there is a food catcher, and if so, how do I clean it? JSBravo
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Dan
Posted on Mar 16, 2011
I have a Kenmore Elite Ultra Wash Dishwasher 665.1319 and it won't get rid of the water it used completely
check the positioning of the waste water hose from the pump
it could be kinked from the re-installation, too high to drain or other re-modelling problems
Sep 04, 2015 | Kenmore Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Dishwasher will not drain ...kenmore ultra wash..goes through cycle but water stays in bottom
Failing to drain is either a blocked drain line or a broken drain pump. First check inside for blockages. When you first turn it on, you should hear a click and a whirring, that's the drain pump turning on. If you don't hear this, your pump is not working. To replace the pump you will have to order the right part, remove the front panel and install it. It usually goes in from the front, bottom, but it's much easier if you remove the DW and tilt it on it's back. It's a fairly simple install, 2 hoses, 2 wires, a few screws and it drops right in.
If you do hear the pump working, then you likely have a clog and you'll want to trace along the drain line to isolate and remove it manually.
Nov 20, 2010 | Kenmore Dishwashers
Water is not draining completely from the dishwasher. About 1-2 inches remain in the bottom. Seems to drain most of the water during the wash cycle, but a bit remains. Thoughts on how to fix this?
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Jan 30, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Kenmore 16522 Built-in Dishwasher Logo
217 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
