Question about Fujitsu 24C1 Air Conditioner
I have a Fujitsu Remote # Ar-FB2 taht is not working for my Fujitsu Halcyon Model # ASU9C1 AC. sER # E001746. Batteries have been changed and new installed. Darrell Steberg
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
  • 10 Answers
SOURCE: can't open the remote controller on Fujitsu Model
Try tighly gripping both sides fo the slide down section to loosen it then slide it down wards.
Posted on Jul 15, 2010
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Testimonial: "THANKS"
SOURCE: My Fujitsu Halcyon Split ac/heater wall unit is
hi i have fujistu inverter2500/600 and it is shut down after 3 minutes after starting up
Posted on Dec 19, 2010
Aug 1, 2015 Where can I buy Remote for Fujitsu ASU18C1 quickly?
from a fujitsu service dealer or service agent for fujitsu ac
Aug 02, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Ar ab9 fujitsu
There is no such reset to this remote control. Just take out the batteries from its battery compartment, and re-insert it after a minute. The remote control will reset itself.
Jan 16, 2014 | Fujitsu Televison & Video
Fujitsu remote control Model AR-DL10. I need to change the batteries. I can pull the slide down to expose the set/ swing/ energy save, but I think I have to pull it further down to get to the batteries. ...
How to get to the batteries in a AR-DL 10 Model Fujitsu Remote Control/ A/C
Pull it down to expose the controls inside.
To pull it down further to expose the batteries: PINCH BOTH SIDES OF THE slider at the top where it is knurled so it will bow out a little bit in the center AT the same time you may need to
slide an object under the slider to help it bow up a litter further.
WHILE DOING THIS: pull the slider further to expose the batteries. There are two plastic stops that the slider must clear to pull it down enough to get the new batteries placed. Before putting it back together: File down the two stops with a nail file so it is easier to do next time. - Who engineered this?
Sep 11, 2010 | Fujitsu (FPCRC04AR) Remote Control
Fujitsu air conditioning remote control not working (model AR-NJ1) . Tried different batteries with no result. Thanks!
open the remote and carefully look at where the batteries make contact they sometimes bend in and dont make contact just pry them out a little and reinsert batteries and it often will work again
Jul 07, 2009 | Heating & Cooling
Replace remote control unit model ar-fb2
Jan 15, 2009 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
821 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
