Question about Charging & Starting Systems for Ford F350 Regular Cab
2006 ford f350 not charging dual battery(new) single alt (new)! replaced batteries no change replaced alternator no change any help???
  • 35 Answers
Check all earth straps for good connection to chassis. Undo and clean as necessary.
Posted on Mar 16, 2011
Charging problems 2001 e350 power stroke diesel
u should check for the wiring,install parts doesn't help,it sounds like wiring problem,check for Alt input & output.check for fuses.
Jan 27, 2014 | Charging & Starting Systems for Ford F350...
2006 Ford Fusion Charging System on
Take your car to Auto-Zone or O'reilly and have them to test your alternator.
Feb 23, 2013 | Charging & Starting Systems for Ford F350...
How can you tell if your 2000 F350 dually has dual alternator,secondly i just replace the primary battery and secondary hold a charge,today the truck will not start the dome lights went out as i begin to...
Did you put a battery of equal or larger cranking amps, if you have dual alts it would be very noticable as you would see 2 alternators. You may also need to replace the other battery also, as this is not a primary and secondary batteries but equal batteries.
Jan 27, 2011 | 2000 Ford F350 Super Duty Super Cab
Battery light came on on my way home from work have super duty 250 diesel 03
Most of the time,the battery light means that the alternator is not charging,or not charging enough.Have it checked,or check it yourself,using a volt meter,attach it to the battery,either one of them,the reading you are looking for is,13.65,to 14.25,volts.Do this with the engine running,and the head lights on,and the ac on,high blower .If it reads any less,the alternator is not charging correctly,or not at all.Check the plug in on the alternator,and the large wire on the back of the alternator,to make sure it is tight,they will vibrate loose on a diesel.If all this checks out o k,then replace the alternator.Charge the batteries up all the way with a slow 2 amp trickle charger,this may take a couple of days to charge,but the slow charge is worth it,it will prolong the battery life,and have less load on the alternator,I hope this was helpful,and thank you for using fix ya!
Jan 05, 2010 | 2006 Ford F-250 Super Duty
Charging system
If you have changed the alternator and regulator, about all that could be left would either be a short circuit that is draining current away, or a bad ignition warning light bulb. That is because the power to energize the field of the alternator, comes through this dash bulb.
Jul 18, 2009 | 1984 Ford F 350
84 ford F350 6.9 diesel charging system not charging batterys new alt,New voltage regulator, new positive and negative wires,
look for a fusible link out. You need to check for output on the alternator that you installed. make sure the batteries are fully charged before that, otherwise its not going to read right. start from the source. also, you can disconnect the batteries from the sys and do a continuity check on the wires in the loom, so you can see if current has a path, or if you have an open circuit. hope this helps
Jul 18, 2009 | 1984 Ford F 250
Charging system
the ALT should charge from 13 v to 15.75 v less than that u need to replace the alt and u can check by ur self by use any voltmeter
Mar 15, 2009 | 1991 Ford F350
1999 F350 diesel 7.3 single alternator system
you may have a bad plug wire to the back of the alternator you can test that with a light tester but when you replace a alternator in a diesel at start up it takes about 35 secands before the unit will kick on
Oct 15, 2008 | 1999 Ford F350 Regular Cab
2001 F350 Charging problems
actually the only thing i can recomend is to have the alternator replace again for warranty and before starting the truck charge the batteries very well with a baterie charger make sure to charge them individually because with a low batterie the alternator has to put a lot of load and might burnt again
specially with dual batterie.
Jun 03, 2008 | 2001 Ford F350 Super Duty SuperCab
Charging & Starting Systems for Ford F350 Regular Cab Logo
680 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
