Question about Emerson EWF2004 20" TV
I have an Emerson EWF2004 20" TV. We are using a RCA universal remote. I hit some button and know I have number in all four corners of the screen that I cannot get off. Therefore my dish network remote will not work either.
    President:
  • 1,140 Answers
Hello -
You've accidentally entered the service mode. You can exit service mode by switching the TV OFF using the main power button on the front of the TV. When you switch the TV on again using the main power button, the numbers should be gone and you will be able to resume watching TV normally. If the numbers are gone, but you are unable to see the Dish Network channels, you will also need to change the INPUT on the TV.
If the numbers are still there when you power on again, there may be a fault with the TV. Please try the above first, then let me know if you need further assistance.
Regards,
BElectric
Posted on Mar 16, 2011
I want to program my universal remote to my Emerson TV (LC220EM2)
Hi all.
1. You must find the model number of your RCA universal remote.
2. You must search RCA.com for it or else google.com for "[model number of RCA remote] + operating manual"
Ignore all those who listed codes.. they have no idea what universal remote you have. All universal remotes have different code databases.
BTW... You most likely will not get any universal remote to work well with your TV. When you get done fiddling with universal, know that you can always purchase the OEM remote from link below (guaranteed to work without programming): SYLVANIA NH001UD Emerson LCD TV Remote Control
Oct 15, 2012 | Emerson LC220EM2 Remote Control
The small black rca universal remote lost code book and need a code for a emerson tv
Hello
There are so may RCA model remote controls with black colour. If you send the model number of your RCA remote control I will try to send the codes for Emerson. Its model number will be either on its front or back cover, or inside the battery stop lid. Anyway I hereby give you some universal remote control codes for RCA with Emerson TV. Just try them.
011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064, 065, 067, 075, 076, 079
Four digit universal remote codes for RCA are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jun 23, 2011 | Televison & Video
Ok i have a rca remote trying tp program it to a emerson tv do not have any codes
Here are some codes for your Emerson TV.
065,067,075,076,079
011,026,027,028,029,030
031,032,037,042,053,064
Here are some instructions as well for your RCA Remote:
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Hope that helps.
Aug 22, 2010 | RCA Universal Remote Control
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Sylvania 27" derailed by Emerson universal remote
CHECK YOUR TV MANUAL FOR REMOTE INSTRUCTIONS IF STILL HAVING PROBLEMS CALL EMERSON AND TALK TO THEM ABOUT YOUR PROBLEM
Aug 25, 2008 | Orion STV2763 27" TV
I need to program my remote to my tv
hit the stop button after it has found the code..
May 10, 2008 | RCA Universal Remote Control
Need code for Emerson TV,DVD,VCR Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
LOST REMOTE
found a remote that works at radio shack. RCA 4 device remote model #RCR4383N. I first tried to manually enter the emerson codes but they didn't work. Used the automatic code search and it was working within minutes. The input-tv/vcr button on the bottom right of remote switches between AV and coax like it should...$10.00
Aug 02, 2007 | Emerson SpongeBob SquarePants TV
Emerson EWF2004 20" TV Logo
53 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
