Question about Orbit Sprinkler System Power Source Transformer #57040
Orbit Model 57896 I can only get 4 stations I seem to have lost two that I did have.
  • mjlyons Mar 16, 2011
    Thanks for the suggestion, in a lot of electronics that works so it was a good try , but didn't work. Thanks again any way.
    Jack
  • 927 Answers
Try removing the battery, unplugging the timer, plugging the timer back in, pushing the reset button (if you can find it) and try reprogramming for all 6 zones. Post again after trying.
Gary
Posted on Mar 16, 2011
  • 2 more comments
  • Gary Nigro
    Gary Nigro Mar 17, 2011
    What exactly is the problem? Is it that Zone 5 and Zone 6 don't come on or is it that the timer doesn't show Z5 and Z6 running time?
  • Gary Nigro
    Another thing you can try is to use Program B for all zones instead of Program A.
    If the timer appears to be operating, you could have a wiring problem to those two zones.
    Gary
  • mjlyons Mar 17, 2011
    Thanks Gary, it wasn't really a wiring problem but while I looked into that I noticed a couple of screws weren't tight at the top of the circuit board and those two didn't make contact I guess.
    Thanks again.
    Jack
  • Gary Nigro
    Gary Nigro Mar 20, 2011
    I'm glad that the loose wiring was the source of the problem. I am an irrigation contractor and when two zones go out simultaneously, it usually is related to wiring, not the timer.
    Gary
I need a manual for the Orbit Model 57896 sprinkler timer.
Try Googling (orbit)(57896)(manual) without parens.
Apr 17, 2018 | Orbit Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
How do I cancel old program and reprogram?
Did you check out the instructions that came with your Orbit? If lost download a set from their web site.
Oct 26, 2015 | Orbit 4 Station Sprinkler Timer With Easy...
We have had it for 2 years and it just stopped turning on. I have tried reprogramming battery good what else can I do?
Pull the dial toward you.
Line up the correct time of day to the arrow.
This may help in the event that the power went out at some point.
When that happens,
it changes the time when your lights turn on & off.
Apr 15, 2015 | Orbit Underground 57896 6 Station In/Out...
No AC fault in Orbit Sprinkler Timer Model 57896
Call Technical Support at Orbit. The 800 number should be listed in the instructions.
Apr 17, 2014 | Orbit Underground 57896 6 Station In/Out...
Wiring new sprinkler timer one wire on my old
Just cut the common wire and put one end in each of the 2 pins. The rain sensor just interrupts the signal to the valves when wet.
Nov 04, 2013 | Orbit Underground 57896 6 Station In/Out...
Where is the fuse on an orbit model 57896 sprinkler
The fuse is the 120 volt circuit breaker.
Check outlet for power.
If outlet is outside, it should be on GFCI, which might be located in kitchen or bathroom or garage.
Use circuit analyzer on outlet to check for correct polarity and ground.
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 24, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Orbit Sprinkler System Power Source Transformer #57040 Logo
917 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
