Question about Zanussi Dishwashers
I have a zanussi ZSF2440 dishwasher, when it turned on by the power button on the front you can choose a cycle and start it, Once the cycle is started it fills up with water but doesn't stop until it over flows setting off the flood protection, which cuts the power, so all the lights on the display go off and stops the water flow and drains the dishwasher and keeps draining the dish washer while the flood protection is on. It seems as if the dishwasher doesn't know when its reached its correct water level for operation and over fills.
silly girl
  • 513 Answers
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Posted on Mar 26, 2006
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Posted on Nov 26, 2008
vector006
SOURCE: Cycle starts then stops and Intake/Drain light comes on
Hey All.
I had the same problem with my Miele g843, and i finally got to the root problem.
My machine would drain ok, and fill ok, but when it tried to start a cycle, it would do nothing. I could hear a relay occassionally clicking until it finally gave up and signalled the blinking red light of death.
I first checked the inlet filter, drain pump and drain pipe but I discovered no obstructions. So I started taking the dishwasher apart, and discovered that the main pump was seized! This may not be the source of YOUR problem, since it could be many things, but this worked for me. Here are the instructions to remove the pump and get it moving again:
Pull out the dishwasher and disconnect the power, water and drain lines.
Empty all water from the unit (disconnect drain line and let the water drain into a low profile container) you may have to elevate the unit and tilt it rearwards to get the remaining water out.
Remove the side panels of the machine.
Lay the unit on its side elevated about 2-4 inches above the ground (be careful you don't put direct pressure on any of the internal components when you support it)
Remove the 4 screws that hold the base panel to the frame of the machine.
You can now see the motor.
Disconnect the electrical connections to the motor and the pressure sensor.
Disengage the clamps that hold the rubber hoses to the motor and slide the hoses off the motor.
Unscrew the single bolt that holds the motor inplace on the back panel of the machine. Pry the rear panel out slightly to release the dowel pins and gently pull the motor towards you (pivoting on the inlet grommet). Once you have the motor out, you can try to manually turn it by rotating the impeller. If it is stiff, you could have the same problem mine had. Using silicon spray with a nozzle extension, spray the seal between the impeller housing and the motor and continue to spin the motor manually until it becomes free spinning. If this doesnt work for you, you may need a new motor ( i never priced one out but it cant be cheap ).
If you get stuck somewhere email me and i can send you pictures: vector006 at hotmail dot com
Cheers!
Posted on Mar 01, 2009
My machine seems to be stuck on a drain cycle
Sounds like your 'anti flood' system is activated. This happens when a leak fills the drip tray on the base of the machine, and a anti flood float switch senses water in the tray. Leaks can come from several sources - loose pipes, leaking door gaskets - even opening the door while the machine is hot! i.e. to add an extra item after the machine has started, for example. ISOLATE THE POWER and examine the base tray, if its a free standing machine tip the machine back at an angle (The Hemlich manoeuvre for Dishwashers lol) and the water will flood out - if built in, remove the lower front panel. Once the water is removed, the machine should start - but if the problem occurs, the leak is still there. Zanussi machines are tricky - you'll probably need an engineer to sort it out - expect not much change out of £100. Cheers!
Oct 16, 2015 | Zanussi 18 in. DCS12W Free-standing...
Zanussi zsf2440 overfilling
The pressure switch controls the water level.
Without water, contact is closed.
In addition to checking the electrical correctness the pressure switch and check the tightness of the hydraulic circuit of pressure switch.
Dado
Sep 02, 2014 | Zanussi Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
Zanussi ZDT 6252 dishwasher will not work
Almost certainly the control board has gone faulty. The favorite is the transformer burns or the thyristor gets very hot and burns due to a bad solder joint. Quickest no noncense repair is to bite the bullet and install a new board.
Jun 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Sep 19, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwashers Logo
117 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
