Question about Compaq (CDD480172) CD-RW Burner
My cd/dvd burner driver is not working nor will it open
    Scholar:
  • 82 Answers
Sounds like the drive likely died or became disconnected within the laptop. Since it is a laptop you should take it into a compaq service provider and ask them to replace or repair it, it will likely be cheap and fairly easy. I wouldn't recommend doing it yourself however, unless you are familiar with the innards of a laptop. Hope this helps, good luck.
Posted on Mar 15, 2011
CD/DVD burner in Compaq Presario 5010NX w/ VistaBasic Reads and any DVD but has problems with CD's. If I load a music CD, sometimes it will open right up and I can play the music. Most times it just...
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
Mar 14, 2011 | Compaq (CDD480172) CD-RW Burner
Works not
make sure that the cd-rw/dvd-rom burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 09, 2011 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Ok so my compaq presario windows xp home edition service pack 3 cd burner was working fine till just a few minutes ago Windows Media Player said Connect a burner. I unistalled wmp and reinstalled still had...
make sure that the cd burner is getting enough power test all leads that are attached to the cd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 03, 2011 | Compaq (CDD480172) CD-RW Burner
I have a mad dog multimedia dvd burner it was working greak i had to redo my computer now it no longer works dont know what to do
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 02, 2011 | Mad Dog Multimedia DVD±RW Dual Layer...
Drawer opens halfway and has to be pulled open far enough to insert disk. Sometimes opens all the way --- baffling.
hope this helps
Dec 31, 2010 | Samsung SHS222L DVD+R Burner
I am having P3 system in which i got cd rw/ dvd rom but it unable to open a dvd. cd is working fine. I have windows xp installed on it. Please help
hope this helps
Dec 20, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Will not open?
Get a paper clip or something thin that will fit in the hole on the front panel of your burner.
push the paper clip in the hole and push till the tray opens.
Hope that helps
Dec 17, 2010 | Compaq (200356-001)...
My drivers for cd-rom does not work
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 16, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
My dvd rom on my Dell Inspiron 2200 is not working properly
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 14, 2010 | Dell Inspiron 2200 CD-RW/DVD Drive Combo -...
No driver found
www.driverguide.com have a driver for you using GMA-4020B you will need to join
Feb 17, 2008 | LG GMA 4020B DVD-RW Burner
Compaq (CDD480172) CD-RW Burner Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
