What is the load capacity for Hotpoint VBSR2080 Washer?
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Washer wont spin
There are probably 12 causes for a washer not to spin,,,,I will
give you the least technical cause...the belt may be loose or
broken.
Regards,
Dennis
Aug 20, 2014 | Hotpoint HTWP1000MWW White, 3.4 cu. ft....
What size drum capacity is ths machine?
Besides visually looking at the capacity, what are you looking for?
Jul 24, 2013 | Hotpoint WMA64 Front Load Washer
Vbsr2080 woww
If the drum is spinning then it's the pump if not then it could be the motor or belt
Jul 21, 2013 | Washing Machines
Could you tell me the load capacity to the hotpoint wma64 please
Maximum load 5.5Kg
Wash Load Examples:
Two examples
of maximum
wash loads for
different types
of fabric.
COTTON
2 Bath Towels
5 Shirts
6 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 5.5kg
SYNTHETIC
2 Children's
Dresses
4 Shirts
4 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 3kg
Jul 29, 2011 | Hotpoint WMA64 Front Load Washer
The maximuin wash load capacity is 5kg, but only half this for a drying cycle.
Hope this information helps.
Jan 16, 2011 | Hotpoint Aquarius WD63 Front Load...
Washer walk in spin cycle
Might just be un-level however the tub is suspended on four spring loaded rods and the lateral movement is managed by four rubber bands called bungy straps. With age these stretch and make movement sloppy to the point of allow water to slosh out on some settings. Remove the front panel and do a load. Watch the tub while it is doing a load. Here is a video that shows how to remove the front:
Dec 10, 2010 | Hotpoint Super 3.2 Cu. Ft. Capacity Washer
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
Hotpoint aquarius
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Apr 10, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
