Question about Coleman Heating & Cooling
House heater does not blow hot all the time. the furnace kicks on and then shuts of and then the blower just blows cold air. the furnace tries to kick on three times but shuts off, sometimes it works just fine. intermittant problem.
  • Hannah Schroeder
    Hannah Schroeder Nov 22, 2017
    I'm not sure what it means if the furnace tries to turn on three times before shutting off and blowing cold air. My heating system sometimes blows cold air, but I can't get the furnace to turn on at all. Maybe we should both find a professional that deals with heating systems to see if they can fix it. http://www.scottsheatinganchorage.com/he...
  • 1,420 Answers
When it blows cold air, there should be an error code blinking on the LED light located on the PC board. Look through a small viewing port in the front panel, then remove the front panel and on the reverse side there should be a diagnostic code chart to help you figure what is wrong.
Posted on Mar 16, 2011
SOURCE:
My electric furnace constantly runs.. no cold or hot air blowing through the vents.. red LED light blinks 4 times saying limit switch open.. how do I fix the problem?
You'll need to replace the fan limit switch. This little switch is what tells your blower when to kick on and when to shut off. It's stuck open.
Mar 05, 2015 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
I have a Dayton Furnace Serial# swglm033942 and need some information; My furnace is installed in the attic and sometimes it will not blow hot air. I have tried to start it and the burners start up, but...
Please have this checked out by a technician. If there is a crack in the heat exchanger it could do just as you described. The blower blows air into the combustion chamber and blows out the burners.
Jan 07, 2011 | Dayton Gas Furnace Heater
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
The floor vents in our house are blowing cold air instead of hot. What can we do to fix it? What would be causing this?
If the furnace is running and the registers are blowing cold air you have a problem with the furnace. Check to be sure the pilot lite is lite if this is a standing pilot, if not check to see if there is a flash code in the site hole in the bottom blower door of the furnace. Be sure the thermostat is set to heat and turned up.
Jan 02, 2010 | Heating & Cooling
When i have the heater/defroster on the heater below blows cold air while the defrost blows hot. when i switch to just defrost the bottom heater stays on and blows cold air. when i have front dash and...
It sounds like you have a blend air door stuck. This is in the housing of the heater a/c blower unit under the passenger side of the dash. There is a motor on the top of the housing that could possibly be stuck or on working.
May 10, 2009 | 2003 Dodge Durango
Heating & Cooling Logo
301 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
