I HAVE AN AVALON WOODBURNING FIREPLACE INSERT, INSTALLED APX 1993. I NEED THE SUPPORT ROD AND ROD WITH THE PERFERATED HOLES IN IT TO BURN MORE EFFICIENTLY. I AM NOT SURE WHAT THEY CALL THE PIPE WITH THE HOLES IN IT THAT CAUSES THE GASES REBURN TO MAKE IT MORE EFFICIENT.
    Brigadier General:
  • 4,736 Answers
Avalon Wood Burning fireplace Inserts are manufactured by Travis Industries. They are very protective of the retailers and will not field any questions or sell parts directly to the customer. With that in mind, you'll have to go back to the dealer you purchased it from (if they are still in business) or go to the link below and search for the dealer nearest to you. The tubes you require are part of the "Air Wash System".
http://www.avalonfirestyles.com/where_to_buy/
Hope this helps. Please let me know.
Posted on Mar 16, 2011
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Rusted Ash Pan
They sell stuff for that at manards you could make your own send me pick
Apr 04, 2014 | Deckmate Sonora Wood Burning Outdoor...
Napoleon NZ26 woodburning fireplace smoking back.
Get someone to come and do this correctly. You have a possible carbon monoxide poisoning hazard!!
Nov 18, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
How to install fireplace insert
need to consult a fireplace store or the project center at home depot/lowes..
Nov 12, 2013 | Smith AO Pool Pump Motor
Vermont casting fireplace vcef33
You could take a table lamp or a drop light a electric drill or anything similar,and see if you can unplug the insert and plug one of these items in and see if the plug works
I am taking for granted that you can get to the plug without having to pull the insert out or at least not all the way out
If you can't do that
Turn the breaker off to that circuit pull the switch out and make sure nothing is touching
Hook a tester to the wires and then turn the breaker on and see
If you have power to that switch turn the switch off and on watch the meter and see if it does turn on and off
If you have power coming out of the switch.
and you can't reach the plug then you only option would be to pull the insert
As for a fuse there may be one but not look like what you are thinking a fuse will look like it is usually a temperature fuse that is shaped similar to a diode the symbol for it can be two ways
it could have what looks like a c laying on its side upright and also another c beside it on its side aiming down like a snake crawling. The other symbol looks like a rocket with no fins on its side with a with a what looks like a T laid sideways coming off one end
Oct 20, 2013 | Heating & Cooling
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
