Question about GE Ovens
Model # JTP11WP...Oven was on cleaning cycle...F2 warning came on...oven has been shut down and is cool..however F2 warning continues to beep and won't stop....Turned off circuit breaker and turned back on it continues to beep.....Chris
  • Anonymous Mar 31, 2014
    there is an annoying sound while the oven is cooling down. How can I turn it off?
  • GE Master
  • 11,800 Answers
F2 signals overheating or, generally, a incorrect temperature reading. So either the fan or the temperature sensor have failed and you will have to replace it. The beeping is generated by the controller board to notify you that a critical error occurred and the oven will not work until the failed part is replaced.
This is the sensor http://bit.ly/erc2c3
you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left, held in place with two screws.
Unfortunately the motor for the fan is no longer available, its production has been discontinued. The only source for it are repair shop that have dismembered old appliances.
Posted on Mar 15, 2011
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven. I haved turned off power at breaker and restarted. Fault reoccurs. Oven is definitely cool. It has been 36 hrs...
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Nov 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
F2 error
what is solution
Dec 08, 2007 | Ovens
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
78 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
