Question about Dell Studio 1737 Laptop
Wireless will not come on and detect networks
  • 1,940 Answers
First, ensure that your Wireless Switch is enabled, and the WiFi status light is on.
Wireless Connections
If the network connection is lost - The wireless switch may be off. To turn on the wireless switch, slide it from the rear to the front of the computer until it clicks into place.
The wireless router may be offline or wireless has been disabled on the computer.
• Check your wireless router to ensure it is powered on and connected to your data source (cable modem or network hub).
• Re-establish your connection to the wireless router:
a. Save and close any open files, and exit any open programs.
b. Click Start ? Connect To.
c. Follow the instructions on the screen to complete the setup.
If none of this gets your wireless working again, you will need to reinstall the Wireless Drivers here:
32-bit Download
64-bit Download
If none of the above fix your Wireless connection, you may have a faulty Wireless Adapter.
Posted on Mar 16, 2011
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
Hi, I have a Intel PRO/Wireless 3945ABG network adapter. It detects all the surrounding networks except mine! I've tried using older drivers as well as the latest one, nothing works! Can someone please...
Well if Detects all others N/w than tour own it has to be a Problem with the Wireless N/w
Check if u are Able to go online wireless on Other Computers
Try Changing the Wireless Channel on Router
All the BEST !!!
Oct 01, 2010 | Intel PRO/Wireless 3945ABG Network...
Not detecting wireless network
Make sure the wireles button is turned on if it is a notebook.
Make sure the drivers are installed and upto date.
Make sure the router is turmed on and the wireless light should be on. (install the router if u had received any cd along with the wireless router.
if still your wireless connection is not detected simply remove all the wireless profiles on the. restart the PC and the router. once it is started the the network should be detected.
Aug 02, 2010 | Dell (430-3572) Wireless Adapter
Wireless not detected
Are you broadcasting your SSID 'Network ID" If not you won't see a wireless network if "SSID Broadcast" is turned off in the router.
Login to your router config page and enable 'Broadcast SSID"
Nov 22, 2009 | Acer Aspire 3000 Notebook
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Wi-fi connection
1. First, you have to make sure that the Wi-Fi of your laptop is turned on.
2. Make sure that there's an available wireless network in your area so that you can test if the computer can detect any available network.
3. If you're running Win XP, right-click the wireless icon on your system tray and select "View available wireless networks"
4. If you can't detect any wireless network, right-click the wireless icon on your system tray and select Open Network Connections.
5. Right-click the Wireless Network Connection icon and make sure to enable it.
6. If it's already enabled, try to disable it and then re-enable it.
7. If you can't still detect any wireless network, try this:
- Click the Start > Run > type msconfig > hit Enter
8. Locate the Wireless Zero Configuration and click on it once.
9. Once it's highlighted, locate the Start button on the upper left hand corner of that screen.
10. After starting the Wireless Zero Configuration (WZC), try to detect the wireless network again.
Apr 08, 2009 | Advent 4211c Notebook
Wireless card not detecting!!!!
I had simalar problems where I could not detect my wireless network even though I could get on the internet I could not see the other computer on my network. I finally after trying everyone else's advice which did not work, found a program called Network Magic. You can purchase it from www.purenetworks.com for $30.00. It took care of all of my network problems and even shows a nice map of how my network is setup and what computers are logged onto the network and even what software like Windows Xp or Windows Vista is on that computer. It will even generate daily logs if you want to show any problems with the network.
Mar 19, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Dell Studio 1737 Laptop Logo
47 people viewed this question
Alun Cox
