Question about GE WJSE3110A Top Load Washer
I have a ge model# wdsr2080d8ww my washer just fills up and never shuts off and eventually runs out on floor is that a pressure switch
jsrock516
  • 5911 Answers
SOURCE: washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Posted on Feb 23, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
  • 6277 Answers
SOURCE: After washing -washer slowly fills with water and
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Posted on Mar 02, 2011
Testimonial: "Thanks- I felt sure water cannot get into the washer unless this valve is mal-functioning--checked price on Whirlpool site--$59.00--cut price to 56"
GE WASHER STOPS DURING WATER FILL WASH AND RINSE LIGHTS LIT.
there is a small plastic tube that runs from the washer tank up to a pressure switch to let it know tank is filled and to start washing. As water fills it creates increasing air pressure in that tubing. If the tube is clogged at bottom end or is leaking ANYWHERE that pressure bleeds off. Those switches are also adjustable via a small set screw on the switch. Is problem affected by load size? If tube leaks usually it may overfill and NOT shut water fill off. Likely the switch is bad, but inspect that line thoroughly.
Oct 26, 2017 | GE Washing Machines
Washer keeps fling with water and will not agitates it will drain and spin
There is usually a small hose from the outer tub to the water level switch. This ia actually a pressure hose to make the water shut off. If a hole is rubbed into it, you loose the pressure and the washer fill will never shut off. That pressure is needed to switch machine from fill to agitate once it reaches the proper fill level.
Apr 07, 2016 | GE Washing Machines
The washing machine will not stop filling, overflowing on the floor.
Not knowing what brand of washer you have.......some fill by time, some by pressure. Sounds like a stuck timer, or bad float switch, or pressure switch.
Jun 22, 2010 | GE Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Overflow
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
When i turn on the washer the water never stops running and it is overflowing into my floor
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Thanks.
May 26, 2009 | Washing Machines
GE Washer Model whdrr418e1ww overflows the tub!
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Washing Machines
GE washer
mostly likely your pressure switch has gone bad or the hose has come loose from the pressure switch. open access to the console. your pressure switch is the water level. if the hose is attached, then the switch itself is bad. Joe
Nov 18, 2008 | GE Washing Machines
Washer continues to fill after full, then spills all over floor until manual shut off
Feb 23, 2008 | Washing Machines
Water fill problem
The pressure switch is close next to the timer switch. There is a thin tube going to the bottom into the outlet pump. Check to see if this tube is free from any blockage, by disconnecting from top and blowing into it. The tube shd be free, and your water will cease to overflow. Refix tube carefully.
Jun 11, 2007 | GE WDSR2080D Top Load Washer
GE WJSE3110A Top Load Washer Logo
137 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
