Question about Alpine CDA-9813 CD Player
I have an alpine cda-9813r head unit and when i try putting a cd in the head unit doesnt seem to recognise it and the motors that pull the cd in don't operate it works fine on radio etc.
ampman
  • 98 Answers
SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Posted on Aug 21, 2007
SOURCE: Screen says searching when iPod connected to Alpine CDA-9847
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Posted on Sep 29, 2008
  • 82 Answers
SOURCE: hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Posted on Apr 17, 2009
  • 11 Answers
SOURCE: No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Posted on Jun 01, 2009
thepot
  • 188 Answers
SOURCE: Alpine CDA-9856 interrupt message
theres a wire loose, bring your car to an audio tech and he'l sort it
Posted on Nov 09, 2009
Alpine cda 9813r. Turns on and off all the time. Checked supply conections and cleaned front face contacts but made no difference.. Fairly sure it is something interrmittent in the unit. Does not seem to...
I had the same problem it was a bad solder joint on one of the surface mount IC's. I reflowed the joint with a hot air soldering station and new solder and it's been fine since the repair.
Jun 13, 2011 | Alpine CDA-9813 CD Player
How do i get my Alpine CDA 9885 head unit out to fit a sub???
Remove the face, and trimring plastic.
There are slots on either side that you put the Alpine unlocking keys into (came with your headunit new) then slide the chassis out.
If you don't have keys - you can use a small allen wrench - or buy them at best buy etc.
A local alpine dealer will probably let you borrow his keys as a good business practice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | Alpine CDA-9885 CD Player
Alpine CDA-9830 doesnt want to work
the cda 9830 and 9831 are known to have issues with the face plate connection that cause all kinds of issues. remove the face plate and clean the contacts on the face plate and the unit.
Feb 07, 2009 | Alpine CDA-9830 CD Player
Dec 12, 2008 | Alpine CDA-9855 CD Player
Alpine cda-w550e manual
I needed a manua for my alpine cda-7897 and went to alpine's website and just type in my unit number under there manual section and there it was in a nice little pdf. file. hopes this helps.
Aug 26, 2008 | Alpine CDA-7998 CD Player
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Alpine CDA-9813 CD Player Logo
65 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
