Question about Hitachi 160GB Travelstar Z5K320 SATA 3Gbs 25 Internal SATA II Hard Drive
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
    Scholar:
  • 82 Answers
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Posted on Mar 15, 2011
    Brigadier General:
  • 10,406 Answers
Try connecting the SATA drive as a "slave" drive in some other computer, to see if it works at all.
If not, exercise the warranty and replace it.
Click Start
Right-mouse click "My Computer"
Click "Manage"
Click "Storage"
Click "Disk Management"
If the disk is working, it should appear in "Disk Management" as an "uninitialized" device.
Initialize it.
Won' recognized my external hitachi z5k320
check data cable.
change use port and check the driver on any other PC.
if problem is same after doing so. check hard drive Cage. change driver Cage
Jul 14, 2014 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
My hard drive is not being recognize
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 06, 2013 | Computers & Internet
Ps3 hitachi z5k320
Return it if it's still under warranty.
For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 12, 2012 | Hitachi Travelstar Z5K320 HTE543232A7A384...
Computer won't recognize external hard drive anymore Hitachi lifestudio
Try connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Jun 07, 2012 | Hitachi 35IN LIFESTUDIO DESKTOP 2TB...
I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Won't back up to hitachi external hard drive
hmmm what backup software are you using, from windows or hitachi? seems if the computer can see the drive, then it's a file formatting issue that you are facing.
May 24, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
Macbook pro os x 10.4.11 won't recognize or mount my new Hitachi xl3000
The Hitachi XL3000 is formatted for the PC, but your Mac should recognize it. Try another cable or port. Check in Disk Utility to see if the drive appears. If it does, then you can format it for the Mac. You can do this in Disk Utility by clicking on the hard drive on the left side of the window. Then choose the Partition Tab, and change the Volume Scheme drop-down menu to 1 Partition. Then click on the Option button, choose GUID partition map, and click OK. Then choose Mac OS Extended (Journaled) for the format and click Apply and OK. Your drive should then format for Mac and mount on the desktop. If it does not appear in Disk Utility after changing the cable and port, or trying another computer, then you may need to return it for replacement. I hope this helps.
Sep 11, 2011 | Hitachi Retail Xl Desk Xl3000 3 Tb...
My computer has two Hitachi hard drives. I had a corrupted Windows XP operating system that went nuts and when I was re-installing WinXP it stopped part way through and stopped. Dropdown window said and...
These are quite an old hard drive and they are probably pass there due date, unfortunately the only way is to replace the faulty drive, I have had these problems and after changing to the later SATA versions I have had no problems since.
You can still buy these type of hard drives but they are getting expensive now as the newer versions are the normal fitted type and the cost for the same size can be half the price. Once they become faulty they really just need to be thrown away.
Hope this helps.
Thanks
Jason
Oct 19, 2010 | Hitachi Deskstar P7K500 HDP725050GLAT80...
Baught a Hitachi HDP725032GLAT80 hard drive. Installed it as a slave drive in my existing PC ... The PC says it's installed and working correctly, but I cannot see it in Windows Explorer??? Have I missed...
Did you format it? The PC won't recognize it until it's formatted, which you can do via Control Panel - Administrative Tools - Computer Management, then click on Disk Management on the left side. You'll see the drive, and have the option to format it right from there.
That's the first thing to check. Let me know if you've already done that and it's still not being recognized.
Jul 26, 2008 | Hitachi Computers & Internet
Hitachi 160GB Travelstar Z5K320 SATA 3Gbs 25 Internal SATA II Hard Drive Logo
618 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
