Question about Xerox Office Equipment & Supplies
We have an old xerox stand alone black and white copier Ser. # 099455. It turns on but never seems to finish it's warm up. When we push the green button to start copying, nothing happens.
  • 643 Answers
What model is it?
Posted on Mar 16, 2011
Need to replace- looking for a package insert to identify the wires exiting the back of the switch
Brand of dimmer? All my Lutron dimmers have 3 or 4 wires, and if it's a simple stand alone, it's two black wires and a green one. green is ground, the others go one to hot, one to the lamp.
If you have a white one and a black one, black is "hot", white goes to the lamp.
May 09, 2015 | Electrical Supplies
How do I unlock the scanner?
There is a green lever underneath the scanner (where the copies exits). Push it towards the rear of the machine.
Oct 07, 2014 | Xerox CopyCentre C20 Black and White...
Xerox C 20 photocopier 'scanner blocked' error message, what can i do?
Try to check green lock under the scanner on the side where your copies went out from copier. maybe you accidentally lock the scanner while trying to get copies.
Hope it helps
Feb 15, 2011 | Xerox CopyCentre C20 Black and White...
Wiring new motor
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
May 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Xerox Phazer 8560
pls replace the catridge & check the logic card.
Aug 21, 2009 | Xerox Phaser 8500/DN Printer
Xerox Regal 5790 Paper Jam
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Apr 10, 2009 | Xerox Office Equipment & Supplies
Xerox 510 color scan option not turned on
HELLO
CALL XEROX ON THE FREE LINE FOR PURCHASING THIS OPTION ON
THIS WILL COST YOU RS:49,000 + VAT
THANKING YOU
RAMANA
Dec 29, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox C 20 photocopier 'scanner blocked' eror message
There is a scanner lock located on the bottom of the scanner. Look where you take your copies out of the machine. On the under side of the scanner you will see a green latch about an inch and a half long and half inch wide.
Turn the machine off. push the scanner latch inward , then pull it back toward yourself until you hear and feel it snap into place. Then turn the machine back on. that should do it.
Nov 18, 2008 | Xerox CopyCentre C20 Black and White...
Warm up mode error
There is a problem with the fuser thermistor in that machine.
You can replace the fuser module you can try looking up on google a business called 'The parts drop" call and see if they can sell you just a thermistor. That's not an uncommon problem. Some of those fusers were made with intermittent thermistors.
Also, you can go into the machine setup and turn the power save OFF. A new machine will come with the power save set to 5 minutes and it will make you crazy.
Sep 06, 2008 | Xerox CopyCentre C20 Black and White...
Al-1641cs can't scan
Dear Zaara.
Please try to copy (xerox) stand alone using printer and if it is copying correctly then the issue could be with the printer software in this case please email me if you need further assistance or you can call me on 9390111676.
If you are unable to copy stand alone the issue could be with
printer.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Aug 02, 2008 | Sharp AL-1641CS Laser Digital Copier
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
