Question about Sony KP-51HW40 51" Rear Projection Television
The picture gets darker.
When I first turn the TV on everything works fine. After about 20 mins the screen starts to flicker a little bit and the picture gets darker. If I tap the side of the tv, it comes back, but then gets dark again. Any suggestions?
  • 125 Answers
Cold solders you may need a tech
Posted on Aug 08, 2008
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Used to flicker, now dead
You possibly need to replace either the Main board, or the power board, they both can be purchased online, and you can either install yourself or go to a site like Onforce.com and accept bids.
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Screen gets darker.
The blinking light indicates there is a problem much like a check engine light in a car.
Unfortunatly this is an older TV CRT based and is problably only capable of 1080i HD resolution if your lucky. I would watch it til lthe TV dies then replace it. If its unwatcable then its tiem to replace this set. If a CRT is going bad then its time for a new TV finding new CRT's is just about impossibel these days.
My RCA 20F510TD 20 in. has sound but no picture
May need a horizontal driver transformer. Rca can not provide a part number. In the future don't buy this junk from China.
Jun 22, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Picture is unwatchable
I have not seen this happen in a long time. Ok first of all that is a sign of poor High voltage regulation, which is not user serviceable. I suggest you find one of the shops on Fixya that can fix this for you, or you can take it to a shop near you.
Sep 06, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Sony KP-51HW40 51" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
