Question about Kenmore Oasis HE 27082 Top Load Washer
How to locate the air dome hose connection port, Note: getting F1 error, checked the clear tube, no cracks, blew through it, OK. Note, press start, it starts to fill with water, stop and get FI, If is stop and strat three times, if fills ok without getting F1 error.
    Problem Solver:
  • 4 Answers
Under top the hose from pressure switch < water level switch> goes to air dome . Check hose for small pin hole or pinch.
Posted on Mar 15, 2011
I have a Kenmore Elite Oasis HE (Model# 110.27086603). I receive an F1 error code after starting the machine. It takes 2 stop & starts to reset. I then receive the F1 error code again at the rinse...
F1 Error Code
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure switch/sensor hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is damaged.
B) Moisture in the air pressure switch/sensor hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing. Blow through the hose to clear any lint that may be trapped in the hose.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub.
D) The control board needs to be replaced.
a. Replace the control board only after the prior steps have been performed, and not fixed the problem.
Feb 27, 2011 | Washing Machines
F1 error alert
Hello there:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
A) Air leaks in the air pressure (switch/sensor) hose.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
the tub.
Read more: http://forum.appliancepartspros.com/washer-repair/7591-kenmore-oasis-f1-code.html#ixzz1A7qKao4I
Jan 05, 2011 | Kenmore Washing Machines
Why does my kenmore oasis washer 110.27042603 show f1 @ every start of load? what part do i need to replace to correct problem? please help!!!!
Customer has F1 Error Code. The control is sensing an error in the signal from the air pressure sensor circuit. CAUSE: CORRECTION: HE Top Load Washers Models: F1 Error Code WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T Serial Numbers: CT01 - CU52 There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed. A) Air leaks in the air pressure (switch/sensor) hose. a. Inspect the hose for cracks, pin-holes or loose connection. b. Replace the hose and harness assembly (W10058730) if it is compromised. B) Moisture in the air pressure (switch/sensor) hose. a. Inspect the hose for evidence of water. b. Replace the hose and harness assembly (W10058730) if water is detected. C) Lint or flashing in the air dome hose connection port. a. Inspect the air dome hose connection port for lint or flashing. b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub. D) The control needs to be replaced. a. Replace the control only after you have completed steps A - C above, and verified that there are no issues with the air pressure system.
Jan 04, 2011 | Kenmore Oasis 27042 Top Load Washer
How do I get the F1 code to go away? It pops up before the machine will start washing and then again before it will start rinsing. (Kenmore Elite) Oasis HE
It sounds like the error code F1 appears whenever the machine is filling. The machine/motor control senses an error in the signal coming the pressure sensor circuit. Either there is an air leak and/or moisture is present in the pressure sensor hose, lint and/or flashing in the air dome hose connection port, or the machine/motor control is malfunctioning.
Remove the three screws from the rear of the console assembly then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub.
Replace the machine/motor control assembly if and only if verified that there are no issues with the air pressure system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses.
NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Dec 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 Error Code on Start up and again at about 17 minutes left on timer.
CUSTOMER CONCERN:
CAUSE:
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
the tub.
E) Make sure you are using the proper HE laundry detergent as excessive suds will damage the unit
Dec 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I keep getting an error code F1. There is NO explanation in the manual just call a technician....what can i do to check things out? the wassher begins to fill up with water then stops abruptly flashing...
HE Top Load Washers
Models:
F1 Error Code
the tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%#
Aug 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
As soon as I put a load in and press start I get an f1 message. I proceed to stop and restart get the same message again restart it again and than finally it will begin wash cycle.
HE Top Load Washers
Models:
F1 Error Code
the tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$%#@
Nov 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
During any washing cycle the washer stops and beeps. F1?? You end up having to press "pause" and start again about 6 times each wash. What can I do to fix it? Is it board?
HE Top Load Washers
Models:
F1 Error Code
the tub.
Oct 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting f1 code and it works but have to restart several times and then beeps through the whole cycle. Annoying!! Help!!
CUSTOMER CONCERN:
CAUSE:
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
Serial Numbers: CT01 – CU52
the tub.
Oct 15, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
When trying to start machine i get a "f1" and beeping
HE Top Load Washers
Models:
F1 Error Code
the tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^#
Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis HE 27082 Top Load Washer Logo
139 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
