The TV remote for my Simtron 2999TB063 was stolen. How can I replace it? Thanks. Jack Clay
  • clayjack Mar 17, 2011
    Your recommended PhilipsCL 034 does not exist. I have checked with the Philips company by phone.
    Do you therefore recommend that I purchase URC-7940 Universal Remote which you originally recommended, or do you have another suggestion? Thanks. JackClay
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Hello
Just buy one URC-7940 UNIVERSAL REMOTE control. With that you cah search and find the code of your TV, eventhough you fail to synchronise with other codes. Manual will also be with it when you buy. Eventhough, I'll give the search method for this remote control herewith.
If your device does not respond to the ONE FOR ALL 4 after you have tried
all the codes listed for your brand, try searching for your code. The Search
Method allows you to find the code for your device by scanning through all
the codes contained in the memory of the ONE FOR ALL 4. The Search
Method may also work if your brand is not listed at all.
Example: To search for your TV code:
1 Switch your television on (not on standby) and aim your ONE FOR ALL
at your TV.
2 Press the TV key on your ONE FOR ALL 4.
3 Press and hold down the M (MAGIC) key
until the red LED underneath the POWER key
blinks twice (the red LED will blink once
then twice).
4 Press 9 9 1. The red LED will blink twice
5 Next, press POWER
Aim the ONE FOR ALL 4 at your Television. Now press CH+
over and over, until your Television turns off (everytime
you press the CH+ key the ONE FOR ALL 4 will send out a
POWER signal from the next code contained in the
memory). You may have to press this key many times (up
to 150 times) so please be patient. If you skip past a code,
you can go to the previous code(s) by pressing the CHkey.
Remember to keep pointing the ONE FOR ALL 4 at
your Television while pressing this key.
7 As soon as your television turns off, press the M (MAGIC)
key to store the code
OK.
Posted on Mar 16, 2011
  • 2 more comments
  • The Knight
    The Knight Mar 16, 2011
    You can check this trik also to get the code of your tV.
    Hello Have you checked the code identification feature? If not check this also. The Code Identification Feature allows you to identify the 4 digit library code stored under your device key. For example, if you want to find out what 4 digit code is stored under your TV device key, follow the six steps below: 1. Press and hold the SETUP button until the red indicator stays on. Release the SETUP button. 2. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Press and release the SETUP button. The red indicator blinks off. 4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the red indicator blinks off the number you pressed is the first digit for the code you are searching for. 5. To find the second digit, repeat step 4, this time when the red indicator blinks off this is the second digit. 6. Repeat step 4 to find the third and fourth digits.
  • The Knight
    Hello
    is your TV is Emerson 32" simtron 2999TB063? If so there is code for universal remote. I'll give you the model number of remote control to be bought and how to set it with.
    Buy one Philips CL 034 Universal Remote control. Emerson is listed in its codes. there are so many codes to try. NB: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON/OFF switch each time before trying an other code.
    Codes for Emerson are:
    EMERSON ....... 0002 0502 0006 0115
    ................. 0506 0706 0520 0906 0316
    ................. 0505 0614 0324 0924 0626
    ................. 0826 0027 0327 0128 0228
    ....... 0632 0134 0247 0605 0705 0805
    ....... 0703 0903 0004 0519 0106 0104
    ....... 0304 0604 0804 0005 0105 0305
    You will get its broshure, when you buy this remote control, and have details about how to synchronize the remote with your Emerson Tv.
    Direct Code Entry
    1. Press and hold the CODE SEARCH
    on, then release the CODE SEARCH
    button.
    2. Press and release the desired Mode
    3. Enter the 4 digit code from the code
    tables. Note: after a valid code entry,
    the red indicator turns off. For an
    invalid code, the red indicator
    flashes.
    4. With your device on, press
    CHANNEL UP. If the device
    responds, no further programming is
    required. Note: If some buttons do
    not operate your device, try one of
    the other codes for your brand.
    OK.
    Direct Code Entry
    button.
    flashes.
    OK.
  • The Knight
    If you have already bought one URC remote according to my advice, It also has code for emerson to synchronise with. You have posted only the model number; that is why I confused. I've searched everywhere; but not found the device. If you wants anymore assistance, feel free to contact me by Fixya. Ok
  • The Knight
    The Knight Mar 17, 2011
    If philips CL o34 is not available, just buy one Comcast On Demand [ Comcast Custom DVR 3 device] remote control. Emerson is listed to that remote control codes. Codes are:20591, 20675, 20821, 21268. You will get it broshure, and it will contain all codes and proceedings.
    If this one also is not available, buy one Radioshak 4-in one Famili Favorites Remote control. It aslo have codes for your Emerson TV. Codes are: 0591, 0675.
    Most of the present universal remote controls will have codes for Emerson listed in them. Check it and buy one. OK.
Key code for simtron tv in a rca control remote
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jan 01, 2015 | Philips Magnavox 27MS343S 27" TV
Simtron tv codigos
083,085,081,000,019 are the codes to check. If you wish to get more, http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Pull up previous posts, either by its left side bar, or view it in Mosaic / Timeslide / Flipcard option.
Aug 02, 2013 | Televison & Video
Simtron TV Remote
Do a code search process with your present remote, and see if any code that get by this process will help to activate all the buttons on the remote control. If you wish to get more details, check this site.http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check the site, and see which brand remote control have setup codes to your TV brand, and buy that one according to availability. Check this site too. http://electrohelponline.blogspot.com/
Apr 29, 2013 | Televison & Video
How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Jul 08, 2009 | LG 42LC2D 42 in. LCD HDTV
No sound
is there sound at  AV OUT  pins  check  with any  amplifier ,  if sound is coming  then  there should be  AUDIO AMPLIFIER IC gone . and  replace it  with same number....
if sound is not coming   then  inside TV kit there should be CHROMA IC gone   and replace it with same number,
this will solve  ur problem
thanks
Oct 25, 2008 | Symphonic SC309C 9 in. TV/VCR Combo
I have a remote control 4 in 1 RCA and dont work with me tv brand SIMTRON
Try this.. turn on your tv. Press the and hold the TV button till it blinks, then press the search button, do not hold it down.. Press it and keep pressing it till the tv goes off. Once it does. Push the TV button again and then the POWER button. TV should come on.. Good Luck
Oct 24, 2008 | RCA 4-in-1 Universal Remote Control
Magellan maestro 4040
if you dont have lo-jack on it there is no way to lock or block it
Sep 23, 2008 | Garmin 010-10348-00 FAIRNG - BLOCK -...
LGE LCD Remote Control no longer works
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) re the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Sep 08, 2008 | LG 37LC7D 37 in. LCD HDTV
The tv sensor is not working on my 42" lg lcd hdtv
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
Feb 12, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
