Question about KitchenAid KUDE60FVSS 24 in Builtin Dishwasher
  • KitchenAid Master
  • 1,902 Answers
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Posted on Mar 15, 2011
  • jackschaeffe Mar 28, 2011
    this worked to clear the clean light. but now it cycles through then wont work unless i do it again.
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ... > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
May 15, 2014 | Ariston Technologies LL65 Built-in...
My dish washer has started to flash Err 7 on the screen and will not work. I ahve cleaned everyhting out, put drainO down the drain, turned it off for 1 week then back on again, checked that the hoses
F7--7 Flashes--Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked
make sure water is getting to your machine, its possible that the hose is kinked and not feeding water sufficiently to the machine.
alternatively, Unplug the appliance.
Take it out of it's position.
Take the left side panel off.
In the large plastic tank on the left side of the machine is the flow meter.
It's a small pcb with a 2 wire plug on it.
Pull the plug off and push it on again.
Do this several times to clean up the connection.
Ensure the connection is dry and tight.
Try the machine again.
If it still doesn't work, you'll need to obtain and fit a new flow meter to try and cure the problem.
Apr 03, 2013 | Dishwashers
Dish washer the clean light stays on and the dish washer wont run
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Jul 15, 2011 | Whirlpool Dishwashers
I have fridgdere dish washer every time I put the dishes in the washer it comes out foggy and discloured pls reply waht to do.
Clean out any junk in the washer. Then put in some new rinsing agent. That should work.
If it's still a problem, put a cup of vinegar into the bottom of the dishwasher while doing a load of glasses and other light dishes . These should come out sparkling and it may help clean some unseen junk in the washer.
Oct 16, 2010 | Dishwashers
Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dish washer not getting the plates clean.
Jan 08, 2009 | Dishwashers
Dishwasher flashing green light
try to open the door and shut it that's supposed to acknowledge to the washer that you know the dishes are clean let me know if it works
May 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Dishwasher Not Sanitizing
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Nov 16, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
KitchenAid KUDE60FVSS 24 in Builtin Dishwasher Logo
382 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
