Question about HP DeskJet F4280 All In One Printer InkJet
Left front of printer. there is a orange light blinking. need to fix it what is it?
    Brigadier General:
  • 10,406 Answers
See the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01365789&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=3390949
for a description of the "blinking lights" problem, and how to solve it.
Posted on Mar 15, 2011
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Turning on wireless capability acer labtop computer
On the Acer Aspire 5570z, there is a physical hardware switch on the front
edge of the laptop. Look for where you plug in the headphones, microphone, etc. Just to the left of those headphones, microphone holes, you should see two switches. Of the two switches, the switch on the left is for bluetooth, the switch on the right is for wireless.
There is an orange light to the right of the wireless switch. With the laptop on and Windows fully loaded you will see this light blink (somewhat slowly) when wireless is on. When wireless is off, the light will not blink except when Windows is initially loading, you will see it blink only once if you watch it carefully.
In order to turn on wireless, you want to move the switch to the right and hold it there for a few seconds until the orange light starts blinking. The switch is spring loaded and will move back to the left when you let go.
If the switch moves too easily to the left and right and is not spring loading back to the left when you let go then the switch is broken or misaligned in some way, you'll have to take the laptop apart and fix the switch, either by replacing it or fixing the alignment.
Feb 01, 2012 | Acer Aspire 5570-2758 Notebook
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
HP 895 Cse printer, orange light blinks and printer won't work
Your printer sensor is dirty clean printer it is in the under carriage of the printer where you put you paper in
Jul 27, 2010 | HP DeskJet 895cse InkJet Printer
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Nov 07, 2008 | HP DeskJet 6540 InkJet Printer
Blinking lights
This exact thing just happened to me. I tried EVERYTHING in the way of troubleshooting - turned printer off/on, plugged/unplugged, opened/closed top, pressed all the buttons on the front right - FINALLY, I took out and put back in both ink cartridges and the light finally went to just green, as it should be AND it printed! Hope this helps!
Jul 31, 2008 | HP DeskJet 5550 InkJet Printer
HELP!
hi, the blinking is caused by a fault in the printer, means it needs to be serviced, its usually more expensive for them to fix it than buying a new one, but you can get there number off the canon website.
Happy New Year
John
Dec 28, 2007 | Canon BJC S300 InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
71 people viewed this question
Seeker5211
Seeker5211
