Question about Athena AS-P4000 Subwoofer
AS P4100 sub. Fuse is blown. Will replacing it fix the problem. Other owners have replaced the fuse without success
Yes unless the cicurle board has something cross and is bowning your fuse.Check your manual and read on there for local your fuse and what to do.If that dose not work.Call the place where you go it from and ask them what to do.
Posted on Mar 15, 2011
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
SWA1501 Sub blows fuses when turned on...
Shorted amp or blown speaker. Other things could also cause it. But there is a short circuit in it.
Mar 08, 2009 | Mackie SWA1501 Subwoofer
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
Sub woofer not working
maby a fuse or blown speakers try to replace the fuse
Jun 23, 2008 | 1999 Ford Explorer
Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Feb 13, 2008 | Harman Kardon HKTS 7 System
No Power to Sub
If you think the fuse is blown replace it take card you use the right one (fuse) then see if it goes.
Aug 31, 2007 | Level 9 Sound Designs MM-1000 Computer...
Athena AS-P4000 Subwoofer Logo
397 people viewed this question
Top Athena Audio Players & Recorders Experts
Eric Sutherland
Len Dipper
Len Dipper
Are you an Athena Audio Player and Recorder Expert? Answer questions, earn points and help others
