Question about Electrical Supplies
I have a generac 6500 r/v generator 6 months old with @ 50 hours on it. The generator starts and runs fine for 10 minutes and then revs very high. Some times it will rev up and down like it is searching for gas?? But most of the time it revs really high untill I shut it down, right away. Thanks for your help!
    Sergeant:
    Champion:
  • 250 Answers
Make sure all the linkages and springs are hooked up on the throttle system and where they pivit is clean. Try moving the linkage by hand gently to make sure there is no sticking and litely oil where the linkages connect. If everything is working properly your internal governor has to be replaced.
Posted on Mar 16, 2011
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
I have a Generac 6500E. The electric start turns over the engine but will not start. Pull start works fine
If the pull start works, but the electric start doesn't try the following. Either give the battery on the generator a full charge, and if after a full charge it doesn't start, get a new battery.
Jan 20, 2013 | Generac GP6500E - 6500 Watt Electric Start...
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
No lights are lit on my Nexus Remote monitor for my Generac standby generator. The generator is working - just went through the testing cycle. Batteries are less than 6 months old. Maybe I need to...
batteries only last about 3 months on these units. make sure you are within 20 ft of the generator and put in new batteries. The green light will blink is a minute or so.
Apr 23, 2011 | Generac Power Systems Generac 5928 Nexus...
Hi: I have a model 0052411 Guardian generator that is putting out 170 volts. Anyone have any idea what has caused this to happen. It has fried any transforms that are in the house. Generac is not much...
Check the automatic voltage regulator .Or if you have a bad neutral connection one leg will be very high and one leg low causing damage to sensitive equiptment.
Oct 19, 2010 | Generac Guardian Series 5502 10 kW...
Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
Oct 01, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Electrical Supplies Logo
147 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
