Question about Video Game Consoles & Games
I have a barcrest psycho cash beast. i have alarm 19-7F coin mech strim bad pattern thats stops me from playing machine. i have tried lots of ways to clear it but no luck. any ideas how to solve this problem? thanks.
SOURCE: Maytag MAH-24 door won't open
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: by pass coin mech for a maytag washer mah21pddww
All you have to do is program the machine to run with no coins Open the service hatch and use the woolens key to scroll through to the setting which is your multiplier setting it may be set to 610 for example you need to set it to 600. While viewing this number use the permanent press keypad to change this setting each press changes it by one increment keep pressing it until it goes back around to 600 Then close your service hatch and the machine will be set to work for free you only have to select which program you want to start.
Hope this Helps
Posted on Jun 17, 2009
SOURCE: alarm says 17-83 opto blocked tamper
Hi did you every solve this problem? i have the same problem currently
Posted on Feb 27, 2010
  • 2226 Answers
SOURCE: I HAVE A FRUIT MACHINE AND THE ALARM WONT STOP IT
contact the company of fruit machine company if you can
Posted on Mar 26, 2010
Electroboy
  • 1749 Answers
SOURCE: hello i have a sharp
I think you mean an XE-A101. Try turning the key to REG mode, take one battery out, turn off at wall for 10 minutes, turn on at wall. Put battery back in. NOTE you will lose any sales in the machine. If this doesn't work, then it is usually a keyboard or printer problem.
If anyone needs a manual for a Sharp XE-A101 cash register, c-tech has it here: http://the-checkout-tech.com/manuals/TOC/cashregisters/Sharp/XE-A101%20operating%20programming.TOC.pdf
Posted on Nov 27, 2010
What is the Importance of Coins in 8 Ball Pool?
This game is all about earning coins. You can become a pro in this game only when you defeat opponents and win lots of coins. As you increase in the ranks, you will get to play with better and more skilled players. The only way to succeed in this game and improve your profile is by earning coins. You will be judged by the number of coins you possess, that is, if you have more coins, you will be considered as a pro in this game. These coins can also be used in the pool shop to buy different items such as table frames, pool cues, colors, chat phrases, and special patterns. For knowing more information about 8 ball pool cheats read it carefully you can easily get an answer here.
Dec 02, 2017 | Facebook Apps
How to get unlimited cash in 8 ball pool
You can easily get unlimited cash in 8 ball pool game.
I am also playing 8 ball pool game. This game is easy and exciting to play and get more coins. I know one place where you can get easily unlimited coins with the help of 8 ball pool hack tool. This tool is very easy to use and will always help us to scrap unlimited coins. 8 Ball Pool coin hack works on every phone or computer that can run the game.
Sep 27, 2016 | Facebook Apps
My Samsung ER-290 cash register has a continuous alarm when turn on I've pressed all the buttons but it won't stop sounding the only way it stops is when I turn the key to off
The alarm is probably complaining you have tried to perform an illegal instruction.
http://www.goodson.com.au/download/ecr/manual/user/ER290%20USER%20Manual.pdf
Mar 10, 2015 | Retail Supplies
I have a 1964 rockola princess and I just got it for Christmas . Right now it doesn't play. I have power to it but it will not select. The carisell is also not rotating. Any suggestions ?
Inside usually on the front of the mech is a three way switch.
"OFF" in the middle and "SCAN or OPERATE" on the outsides.
First hold the switch on SCAN to see if the carousel turns.
If it does, put the switch to operate, it may turn some more but then it should stop, or if there are some selections left on it should play them. If it stops then make sure you can give the machine a "CREDIT" either by dropping a coin in if the coin mech works or find the credit button inside and flick it a few times to see if it puts on credits. If everything's ok you should be able to use the keys to select. If you need more help email me or maybe we could Skype.
Email martinyreg@gmail.com
Dec 25, 2014 | Televison & Video
Mpu5 error codes barcrest
I have a cash beast machine, whenthe unit is powerd up, nothing happens, the mpu5 had got the -12v and the 34v leds on but nothign else, i have looked over the board to check the various status leds and as far as i cansee all of them are on, could this be a power supply problem, or is the card dead, does anyone know what/where i could look to see if i can find the fault, i do have 2 power supplies,. and both leave in the same state, i am tempted to say its not the PSU.
Read More.. HP Printer Support
Thanks,
Aug 18, 2014 | Office Equipment & Supplies
The coin mechanism is hard to push the coin slider, but it works.
Coin mech is held in place with 4 screw heads in key hole slots.
Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
The hex bar is only used to stop the mech going upwards.
Sep 12, 2009 | Whirlpool CAM2752RQ Coin Operated...
Alarm says 17-83 opto blocked tamper
Jul 19, 2009 | Kitchen Appliances - Others
Space Invaders
Awesome find John!
Ok everything else works except it won't coin up?
Open the coin door and look inside, there should be a microswitch under the coin mech, with two wires running to it. Those are what sends the signal to coin up the game. Make sure the wires are connected to the switch properly. There should be three pins on the switch: a common, a normally open, and a normally closed. One wire goes to common and one goes to normally open.
If you look further into the cabinet there should be a Menu and a Service button. Work your way through the Menu with a little trial and error and you can put the cabinet on Free Play, so you don't have to worry about coining it up.
If its even older than what I think you might have to adjust the freeplay settings with dipswitches and that is a whole different story.
-Let me know!
-Captain Jake
Jan 16, 2009 | Video Game Consoles & Games
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
