Question about Maytag Dishwashers
Our dishwasher doesn't get the dishs clean. The Model No. is dwu6750aam- serial10607783qy
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
This is usually caused by either a restricted drain, (usually the problem) or larger than usual particulate under the lower wash arm tower.
The restricted drain can manifest itself:
- At the air gap at the sink (remove cover by lifting straight up then unscrew the inner cap nut and remove the particulate) NOTE the installed position of the upper cap under the nut as it will only go back together in one position)
- At the Air Gap outlet hose connections (remove hoses 2 ea. and inspect plastic tubing)
- At the sink connection. This can be either a direct plumbing connection or a garbage disposal connection. (remove the hose and inspect drain port hole for the connection.)
- At the pump outlet, (remove hose and inspect drain port)
If after doing the above you still have drain problems you will have to remove the lower wash arm and support to inspect the sump area for debris. NOTE: Pay close attention to how the lower wash arm is assembled.... they can end up being a rubitz cube!
Your illustrated parts list is here: (I will list item numbers below)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=44530&diagram_id=28395557#d28395557
Make sure that the lower wash arm (Item 2) and the upper wash arm (item 21) do not have food particulate in the holes.
There is a very very remote possiblity that the pump filter (item 6) is clogged but unless the unit sat with food particulate in it for months of no use it should not be bad.
After doing all of the above you still have the problem it is most likely the impeller (item 13) that has failed.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from www.dishwasherfilter.com. that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Jul 08, 2013 | Dishwashers
Filter doesn't self-clean
hello diane,
i would think that unless your model says it is self cleaning then yes it is normal to have to clean the filters on a dish washer. the amount of time between cleans would depend on how dirty your dishes are.
Apr 20, 2013 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool dishwasher model series 980 doesn't clean dishes as good as it used to
Phosphate was outlawed as an ingredient in dishwasher detergent. If you live in a region with hard water, detergents don't work very well anymore. See the US map of water hardness.
http://www.citriclean.net/why-citriclean/
Mar 19, 2013 | Whirlpool Dishwashers
The lg dishwasher doesn't use all of the detergent and the dishes are not 100% clean
first check the water supply if good water pressure.then check the pump under the bottom dish tray remove parts check for debree.
Jan 25, 2013 | Dishwashers
Dishwasher won't clean?
check to see that the jets of the spray arms are not blocked. Sometimes small pieces of food get into the arms and block the spray so it doesn't clean the dishes well
Feb 29, 2012 | GE 24 in. Profile PDW7800 Built-in...
Sediment is collecting in the bottom and on the dishes. I have tried a cleaning cycle but it doesn't work.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Maytag 24 in. MDBH750AWS Stainless Steel...
My dishwasher doesn't work. It won't clean the
It can be your timer, motor, or water value. I need more detail information.
May 13, 2011 | Hotpoint HDA3520ZBB Dishwasher
Frigdaire Quiet II - Dishes in upper portion are not coming clean
My dishes are not all clean when done washing. Also it doesn,t sound like the not a lot of pressure when washing like it did when it was newer.
Jun 30, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwashers Logo
171 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
