Question about IBM Office Equipment & Supplies
Error 215 code. Looks like a small part that is attached to a spring under the daisy wheel is either broken or loose.
  • IBM Master
  • 3,594 Answers
215 is a print wheel error. If you have the "FLAG" broken it will have to be replaced. You will probably need a tech.
DickyO
Posted on Mar 16, 2011
What is making loud noise by front passenger tire when you go over bumps or turn? It's a very load creeking sound.
could be loose strut springs , strut shocky mount , top strut bearing, loose wheel bearings, suspension mounts.
have it inspected by an accredited suspension shop.
Mar 01, 2015 | Cars & Trucks
The key I push is not the letter that prints
Many factors affect correct character selection. To isolate the problem, follow the directions below:
  1. Is the daisy wheel locked into the carriage correctly?
    1. Open the top, locate the black lever near the hammer and move it away from the platen.
  1. Lift out the daisy wheel. Inspect the petals to see if they may be damaged.
  1. Locate the small spring loaded pin near the center of the daisy wheel hub. If the pin is missing or sticking, or the daisy wheel has damaged petals, replace the daisy wheel.
    1. Look into the opening from where you removed the daisy wheel. Ensure that there is no debris in the area; use canned air to blow out the area.
  1. Reinstall the daisy wheel or install a new one if the old one is damaged.
  1. Remember to push the black lever towards the platen until it snaps into place.
  1. Close the top cover and turn on the typewriter.
    1. After the carriage moves to the left margin, insert paper, and open the top cover.
    2. Push the hammer forward until it presses the daisy wheel petal onto the paper.
    3. It will leave an impression on the paper; it should be a lower case "h".
    4. If the impression is any other letter than those above, the typewriter may require service.
  2. Examine the keyboard area. If there is any contamination, i.e. spills, pet hair, etc, the keyboard may need to be cleaned by a trained technician.
  3. If the problem is not resolved after these actions, the typewriter may require service.
Brother typewriters have a 90 day labor, 1 year parts limited warranty. For 90 days from the date of purchase, Brother International, or its Authorized Service Centers, will repair this product free of charge if defective in material or workmanship. After 90 days, and until one year from date of purchase, Brother will furnish, free of charge, a replacement part for the defective part of this product, you pay for labor.
If your machine is within Warranty, you can contact Brother Customer Support Center at (1-877-276-8437)
Apr 05, 2013 | Brother GX-6750 Electronic Typewriter
My cx 90 brother professional typewriter does not type the correct letter when done manally
First I would remove and inspect the daisy wheel for bent spokes. If that looks ok there may be a problem with the selection plate assembly, but it would take a technician to figure that out. Just make sure you turn the machine off/on if you removed the daisy wheel so it can re-initialize and find the home position of the daisy wheel. good luck.
Sep 06, 2012 | Office Equipment & Supplies
Spring that holds down the roller is not attached.
If you have the spring that was on bushing ( part that missing ) unscrew the screw, stretch spring, and screw it, so that screw holds spring, and you can copy.
Jul 05, 2010 | Canon PC-160 Black and White Copier
Can't get the parking brake to release with handle on 1998 gmc sonoma.
Check the cable attached to the back of the handle sometimes they come loose. May be a pain to reattach but it is simple to do. If it is attached check the spring relaease on the brake if the spring looks stuck press the brake down but do not let it click and then use a small prybar or screwdriver to move the spring. If both of these areas are working check the cable under the truck that engages the brakes to make sure it did not come loose.
Apr 07, 2010 | 1999 GMC Sonoma
TYPING EVERY CHARACTER BUT WHAT I'M ACTAULLY TYPING-
Check for KBII and PS (ketboard II , Proportional space) or any bthing interfearing with the printwheel.
DickyO
Apr 06, 2010 | Brother SX-4000 Typewriter
Daisy wheel seems to be typing wrong characters. Is there a correct orientation for the wheel the typewriter? thanks Anne in Espanola Brother sx4000
type "code" and "reset" it will reprogram itself and get the wheel lined up properly to be correct with the keys you type.
Mar 31, 2009 | Brother Office Equipment & Supplies
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
Mar 20, 2009 | Sony DSR-1500 Mini DV VCR
Snowblower Treads not turning
Check the steel axles that go through the plastic wheels.What happens is the axles rust and swell not allowing the track wheels to turn freely.its a problem overlooked by all the so called small engine repair shops.I have removed the wheels and sanded the axles to remove the rust.I greased the shafts and the wheels move freely.There is a provision on the wheel for a grease fitting.I carefully drilled the holes and with some strong waterproof glue thredhed a fitting in each wheel.
Mar 05, 2009 | Garden
Metal spring has broken under my gas pedal
Put the Brake spring under the gas pedal (think its the same part) and then get a "Squash Ball" (small hollow ball for the game Squash) and tape that in place of the spring, you brake pedal will now feel more firm like a real car....
Aug 01, 2008 | Logitech MOMO Force Wheel And Pedals Set
154 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
