The screen displays "view and
    Master:
  • 388 Answers
Get it to the position then switch ity off at the mains
Posted on Mar 15, 2011
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
When prints come out the landscape is all white .sky and sea ok. photos comes out with lines on them
Verify that the ink cartridges are not damaged and are completely seated in the printhead:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
    For more information view Installing the Printhead and Ink Cartridges:
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
    NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem.
Dec 05, 2010 | Kodak ESP7 PP All-In-One Printer
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
Black ink not printing
Dear Friend, Check & confirm the following will help you...
  • Check ink tank situates Properly
  • OR Install recommended Ink tanks in Perfect Order
  • OR Remove Tape[Confirm there is no Orange tape across the top of ink tank]] From the Ink tank
  • OR Replace Ink tank
  • OR Perform Deep Print Head Cleaning
  • OR The Print Head may Need Replacing
>i860_install_inks_animation Click here
Above picture is the Correct View.... If this helped you,Do rate ME...Thanks For Contacting FixYa....
Apr 22, 2010 | Canon i860 InkJet Photo Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
