We have a veriable length (VB) record EBCDIC file on UNIX and we're trying to send to the MF. The BDW and RDW settings are in place, but the MF doesn't seem to understand, so it cascades the data. Any suggestions on Rumba or Connect:Direct settings?
    Brigadier General:
  • 10,406 Answers
Use 'TYPE E' and 'MODE B' file-transfer options to transfer the file, block-for-block, without converting from ASCII to EBCDIC, and without re-blocking the records.
Posted on Mar 15, 2011
High RDW SD count mean
To what make and model of camera does your query refer, please ?
Jan 02, 2017 | Cameras
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
What is activation key for download accelerator plus (dap94)
Hi
Try this key
3177-6353-RDW-JJGQD-10 or 3177-6353-RDW-JJGQD-10
Jun 06, 2010 | Computers & Internet
What does "Add Output" mean?
Output options allow you to configure encoding settings and send the stream to a file, a broadcast server, or both.
download the easy to follow manual by clicking on the link I am providing below
http://docs.real.com/docs/RealProducer13/RealProducerGUI_13_1.pdf
Jan 04, 2010 | Real Networks RealProducer Plus Upgrade...
Task filter
Following are a handful things u have to know about VB file handling
for more details...go to http://www.5starsupport.com/info/vb.htm
File Handling (Generic)
While VB is working on a better approach (FileSystemObject), the built-in file handling statements are still the only way to access data other than through the VB database capabilities. Your skills in this area can make or break your ability to work with various formats. The OPEN/CLOSE statements are critical to success, but the LOF, EOF, and LEN functions are used even more often! It's also a given that you'll use the DIR function regularly.
Dir - Returns a filename that matches a pattern
temp$ = Dir ("*.*")
CurDir - Returns the current directory
temp$ = CurDir
MkDir - Creates a directory
mkdir ( "newdirectoryname" )
ChDir - Changes the current directory to a new location
chdir ( "newdirectoryname" )
ChDrive - Changes the current drive
ChDirve "A"
RmDir - Removes the indicated directory
rmdir ( "directoryname" )
Freefile - Returns an unused file handle
i = freefile
Open - Opens a file for access, locking it from other applications
open "filename" for input as #1
Close - Closes a file so that other applications may access it
close #1
LOF - Returns the length of a file in bytes
i = lof ( #1 )
EOF - Returns a boolean value to indicate if the end of a file has been reached
statusvariable = eof ( #1 )
Name As - Renames a file
name "filename1" as "filename2"
Kill - Deletes a file
kill "filename"
Fileattr - Returns attribute information about a file
i = int ( tempvariable )
GetAttr - Returns attributes of a file or directory
i = GetAttr("c:\windows\temp")
SetAttr - Sets the attributes of a file
SetAttr pathname, vbHidden
Reset - Closes all disk files opened by the OPEN statement
Reset
FileDateTime - Returns data file was created or last edited
FileDateTime ( filename )
FileLen - Returns length of file in bytes
FileLen ( filename )
FileCopy - Copies a file to a new name
FileCopy sourcefile, destinationfile
Lock - Controls access to a part or all of a file opened by OPEN
Lock #1
UnLock - Restores access to a part or all of a file opended by OPEN
UnLock #1
Width # - Set the output line width used by the OPEN statement
Width #2, 80
File Handling - ASCII-specific
While VB is working on a better approach (FileSystemObject), the built-in file handling statements are still the only way to access data outside of a data base. Your skills in this area can make or break your ability to work with various formats. The OPEN/CLOSE statements are critical to success, but the LOF, EOF, and LEN functions are necessary to build useful code.
Line Input - Reads an entire line of ASCII text
line input #1, tempvariable$
Write - Puts data in a file, with separators for the data
write #1, tempvariable$
Print - Puts data in a file with no separators
print #1, tempvariable$
Spc - Used in a print statement to move a number of spaces
Print #2, var1; spc(15); var2
Tab - Used in a print statement to move to TAB locations
Print #2, var1; Tab(20); var2
File Handling - Binary-specific
VB also support features which allow you to access a file on a byte-by-byte basis. The good thing about it is that you have more control, the bad thing is that you may have to write more code. Generally, a programmer will use the option (ASCII or Binary access) according to the least code he has to write. For binary access the Get/Put are equivalent to the Line Input and Print functions used in ASCII text file access. The big difference between the two is that binary access will read (Get) an exact number of bytes of data, and the reading can start at any byte within the file.
Get - Reads data from a file
get #1, anyvariable
Put - Puts data into a file
put #1, anyvariable
Seek - Moves the current pointer to a defined location in a file
seek #1, 26
Input
input #1, anyvariable
Loc - Returns current position with an open file
i = Loc(#2)
Sep 14, 2009 | Microsoft Windows XP Professional With...
Microsoft Access query in VB
first you need to create a record set to do this, after creating a record set RS1. please follow the code below:
Update the code as per your requirement.
Rs1.Open "Select * from table_name where UserName = '" & UName & "'", Cn1, adOpenDynamic, adLockOptimistic
Mar 14, 2009 | Microsoft Visual Basic 6.0 for PC
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
I want full pdf for vb
Your question isn't clear but if you want source for VB I suggest you www.codeproject.com and if you want PDF file about VB just mail me, I have some and I can send it for you, my address mail is: hussein@fardinfard.com
Feb 24, 2009 | Computers & Internet
I have sato cx400 printer, looking for VB6 code
Try this link:
http://www.filebuzz.com/files/Codabar_C/freeware-1.html
Have a look at the VB Barcode Integration Kit
Feb 04, 2009 | SATO CX400 Thermal Label Printer
File handling in visual basic 6.0
temp$ = Dir ("*.*")
temp$ = CurDir
ChDirve "A"
i = freefile
close #1
i = lof ( #1 )
kill "filename"
Reset
Lock #1
UnLock #1
Width #2, 80
get #1, anyvariable
put #1, anyvariable
seek #1, 26
Input
i = Loc(#2)
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
