Question about Vacuums
Do all four threads get inserted in two needles in husquvarna Serger?You have no listed category to get response and i did pay for this.
  • 10,319 Answers
Read the link below by clicking it on
It is a blog with plenty or results of the do's and don'ts of rethreading the needles
http://blog.heirloomcreations.net/?p=130
Posted on Mar 15, 2011
Can not catching the bobbin tread at the bottom
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 18, 2016 | SewShop.com Singer Model 347 Instruction...
Singer profinish serger
This sounds like a timing issue. You need a professional.
Jan 18, 2014 | Singer Vacuums
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I have a white serger 1600 which I do not have the threading instructions. I have tried to thread it but cannot get the machine to work properly. help!
Here is the you tube website which has a 4 part video on using the
White serger 1600 machine: http://www.youtube.com/watch?v=5kF5ilPxR4Q
I also have a website with instructions threading this machine: http://www.ehow.com/info_8107633_instructions-thread-white-speedylock-serger.html
At the ehow site, you can search for all kinds of information in case you need more than learning how to thread and adjust the stitching. Happy sewing!
I hope this helps. If it does, I'd appreciate you vote. Thanks,
Handie Andie
Apr 07, 2011 | Vacuums
My Babylock Serger Eclipse was bought around 1994 and had a looper threading tool wire to thread it when I could not get it to thread manually. I lost the tool and can't get the thread to blow through....
Try one of the Serger looper threading tools listed on this Amazon.com page: http://www.amazon.com/Serger-Looper-and-Needle-Threader/dp/B000Q30C3G/ref=pd_sbs_ac_1 .
These are third party tools. See the main item and the section "Customers who viewed this item also viewed" for other manufacturer's looper threading tools.
I hope this helps.
Mar 21, 2011 | Vacuums
I have an Elna 745 serger/overlock machine. Whenever I'm doing a double cover stitch hem, when I'm at the end, the thread release lever does not release the thread. To release it, I have to cut the...
There are two methods to release the cover stitch with sufficient slack in the thread. Since you are using the thread release lever, did you set the Brown tension dial to zero? Before changing the tension, you have to first lower the needles to their lowest position in the fabric with the hand wheel and then turn the hand wheel backwards to bring the needles to the highest point in the cycle.
The other method may work better for you. Bring the needles to the highest point in the cycle and lift the presser foot. Then slide a thin object (a sewing ruler, for example) between the presser foot and the feed dogs and pull the needle thread towards you. Cut the needle threads Then pull the fabric away from you before cutting the looper threads.
Both of these options are described on page 98 of the manual, which is available from Elna. The current link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst_Book_745_%28E-F-G-I%29.pdf . Pictures for the second method are available here: https://www.seamwork.com/issues/2015/06/coverstitch-machines . (Ending the double cover stitch hem is the same as that for the single cover stitch.)
I hope this helps.
Nov 27, 2017 | Vacuums
I must not be doing something in the correrct order. Is there a video showing how to thread the husqvarna serger?
Hello. Here is a video and an article on how to thread your serger http://www.ehow.co.uk/how_7412042_thread-husqvarna-serger.html
To see the video, click on the photo. Joe
4 thumbs up please. ty.
Nov 06, 2010 | Vacuums
Janome 6600 sewing machine. bobbin thread is gumming up underneath on a swimsuit knit type material (4 layers). Brand new machine had 1 1/2 weeks. Sometimes material goes down into the bobbin area jammed...
Make sure you're using a polyester thread (I use maxilock serger thread) then a stretch needle, and hold the tails of your thread until you get started into the seam so the fabric cannot push down into the opening on the throat plate.
Also, a small zigzag stitch (about 1.8 - 2.0 wide) is good to use on lycra as that will allow the fabric to stretch after the garment is made.
This is stuff I've used with my 6500P and other previous Janome machines in making Ice Skating outfits.
Oct 17, 2010 | Vacuums
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
