Can not hook it up to Vizio plat screen TV. Please help.
  • 902 Answers
How are you connecting it? if you are connecting via hdmi you must make sure both tv and dvd are on at teh same time. also on some dvd players that have different outputs you must select which output you are using. try using old school rca (red yellow white) cable first
Posted on Mar 15, 2011
I'm trying to hook up extra house speakers to my vizio flat screen TV how do I do that
Hook your TV to a home theatre system. TV.s don't have enough wattage to handle several speakers.
Mar 16, 2015 | Vizio Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
How do i get the picture to show on vizio tv screen i have hooked everything up am i setting the remote to vizio tv wrong
More info would be helpful; model number, signal source, etc.
You probably have not chosen the right 'source' yet.
This would be cable, satellite, or antenna-
Dec 27, 2014 | Vizio Televison & Video
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
Hi, can't get my Vizio TV to see the Wii Console
Through the VCR will not work very well. you need to hook directly to TV input.
Jan 12, 2010 | Vizio VO42L 42 in. LCD TV
NO RGB SIGNAL - VIZIO HDTV TO LAPTOP
I've been online looking for a solution to this problem and couldn't find a fix until today. I just got off of the phone with a Vizio Tech. He told me that some pc's have a way for the monitor to show the screen externally, and that there's usually a button, sort of like the input option on your TV but its an output button for a laptop in my case. It should look like a picture of a TV in and out of each other. Mine was located on the number four key. I had plugged in my wires and put the TV input on RGB. then on my laptop pressed the function key and number 4 key at the same time and what do you know, I had a picture on my screen. I almost gave up on my vizio but love it even more now. I hope this helps.
Jul 05, 2009 | Vizio VX42L 42 in. LCD TV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
Mar 29, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L37
Sounds like a bad av connection on the main board. i would try to connect the xbox via an alternate av connection or hdmi to verify problem. contact vizio support and describe your problem. they have had trouble with this main board. some of their parts have lifetime warranties and the service call is free. changing out the main board is a pretty simple process, about an hour or less. hope this helps.
Sep 28, 2008 | Vizio L37 Television
Screen Problem
This is not a setting problem, either the digital board is going bad or the analog board, could be a loose LVDS cable, that hooks to the power board and the logic board, if you take the back off and hook it back up to the source, then get a plastic probe, do not use any thing metal, you will get shocked or damage the boards inside, take the plastic probe and while the tv is playing move around some cable and see if the picture gets the same problem, if so make sure all the cables are securely seated
Apr 07, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
