My Baxi wm-511-rs boiler GC No 4207708 has been off for a year. The place was rented and they used electric fires. Hot water was obtained again via electrical hot water tank. Must admit I'm not sure if this tank also heats warter by using input from the boiler. I switched on everything, set the thermostat and timer thought I'd bleed the rads nothing came out! So I re-lit the pilot but it won't fire up to heat the house. Any suggestions would be of great help please.
2 Suggested Answers
  • 41 Answers
SOURCE: Gas Boiler will supply /fire
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Posted on Jul 19, 2008
My boiler dosent come on i have no hot water but when i turn the heating on boiler works but still no hot water what should i do
Hot water is gravity fed through your pipes. When you turn the faucet on the water will flow through the pipes. If your hot water heater is natural gas driven relight the pilot. Same if oil fueled. If electrical, check fuse to see if it has blown or the circuit breaker has tripped. If either has tripped, replace it and if it blows again the heater has a serious failure, you might need to buy a new one. If pilot won't light on gas unit, try relighting after 5 minutes, could be a bad thermocouple.
Apr 03, 2015 | Water Water Heaters
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Hiya. I have an old baxi boiler wm 38/RS . The pilot light is on but the boiler will not fire up . Can u help me
Rubbish!
Cleaning the jet is a job ONLY for a gas fitter as it involves disturbing both the case seals and the gas pipework. DON'T RISK YOUR SAFETY, besides which if the pilot wasn't powerful enough it would continually go out.
Check (if you're competant to do so) that there's 240vac across the gas valve solenoid connections. If so then the gas valve will need replacing by a GAS SAFE REGISTERED fitter.
FYV
Jan 18, 2013 | Combi Centre DX - Mango
Baxi solo WM 50/4 RS pilot light is lit, Boiler will heat water but not rads have you any ideas thanks sam
Double check that the programmer is calling for the boiler to fire, and also that the thermostat is turned up enough.... you will hear it click as you turn it up... if the radiators still dont get warm...
then In the airing cupboard there should be a pump on a three port valve that says A,B, and AB on the different pipe outlets... It seems that this is possibly stuck in one position.... Sometimes the servo motor on top of the three port valve (square metal box with wires going into it) goes weak and requires replacement, these are not expensive from a decent plumbing spares shop I.e Pts (plumbing trade supplies) and are a doddle to install, just isolate power to it, take square the top cover off the valve to reveal the innards and you will see it straight away... Like a round brass cylinder with a flat top... It should have two screws holding it in...
Hope this helps
Thanks
Steve
Nov 06, 2010 | Heating & Cooling
We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is...
baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Oct 15, 2010 | Heating & Cooling
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
