Question about Baby Lock Evolve
I bought a used babylock 5280ED. Can't get it to form any stitches. I have examined the threading over and over and don't know what's wrong. Any suggestions?
    Problem Solver:
  • 5 Answers
A bent looper will cause this.
Posted on Mar 16, 2011
The top thread keeps shredding/ripping while trying to embroider. Using a babylock ellure.
as you thread the machine check for burrs, also on the needle plate
Feb 24, 2014 | Baby Lock Ellure
Huskylock 936 will not form a 4-thread overlock stitch
It may be difficult to solve a computer controlled machine with as many options as the 936 serger. Stepper motors control many of the functions. You can check out this video I made 4 years ago to get an idea of where to look.
Nov 19, 2013 | Husqvarna Huskylock Computerized 936
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
Hi! I am planning to buy a babylock machine. iread about, but I still don,t know what to buy between Sofia 2 and Ellure Plus.
Looking at the babylock.com website the Ellure Plus has more stitches although they are both machine embroidery machines. The Ellure Plus has a larger embroidery field than the Sofia though so this may well clinch it, 4" x 4" versus 5" x 7", I know I would go for the larger embroidery field so I didn't need to reset the hoop.
I guess though it comes down to price and will you use all the extra features of the Ellure Plus. If you are mainly doing clothing and home dec then you really don't need the embroidery features at all, its a personal preference though.
Have you been in for a demonstration and used both machines yourself? Sometimes the little things will crystilise the decision for you. Look at ease of threading up, lighting in the sewing area, size of the free arm and how easy it is to program and set up the embroidery functions. Then decide if the extra cost is worth it, sometimes its better to spend more now and not outgrow the machine's functions, but you know what your sewing needs are so its something you have to weigh up.
Sep 13, 2011 | Baby Lock Ellure
Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
May 09, 2010 | Baby Lock Evolve
Serger is not stitching at all. It has something to do with how the thread is installed. Needing a diagram
The diagram is on the inside of the serger door;
Raise the antenna to it's highest position.
Turn the handwheel until the loopers are at their highest position.
Set tensions to zero and raise the presser foot.
Begin threading from right to left, beginning with the upper looper.
Set the tensions back to mid-range.
Lower the presser foot and stitch a chain and if it is formed as it should be you are ready to serge.
There are manuals available for downloading at the Babylock website for the models DX and SX.
May 07, 2010 | Baby Lock Eclipse Serger
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Babylock Eclipse SX won't catch the overlock stitch
  • the factory default settings are 4,4,4,4 and M
  • Change the needles
  • use a can of air spray ( compressed air can sold in computer stores) to ensure there is no fabric or dust under the needle plate
Jun 28, 2008 | Baby Lock Eclipse Serger
Will not stitch still
Have you looked at the shuttle? It should be easy to take out and examine. Make sure everything looks OK then put it back in and try again.
Mar 19, 2008 | Yamata FY14U4AD
Sewing Machines Logo
62 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
