Question about Samsung HT-P38 System
Do i need the brushless Dc Fan Model # RDM50155? it is making loud noises like it is rubbing against the casing i tried to tighten it and losen it but it sounds like a rocket ready to take off ?
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: DVD PLAYER FAN MAKES REALLY LOUD NOISE IT
When fan's shaft got dry, it start vibration in spinning and produce lound noise. Lubricate exhaust fan shaft with good quality machine oil.
Thanks.
Posted on Nov 18, 2009
Our refrigerator is making a high pitched ringing/buzzing sound. Any way to fix this? Thanks!
You need to pull the refrig. out from the wall and determine the source of the noise. It maybe comming from the "condensor fan" usually located at the bottom rear. The blade maybe rubbing against something. Eg. paper or shield around the fan. It is also possible that the noise is comming from the inside. In this case, it could be the "evaporator fan" rubbing against something. Good luck ...Jerry
Mar 04, 2013 | Refrigerators
SMEG A42 fan motor problem
check that the fan mounting screws or bolts are in place and tightened
Aug 02, 2010 | Smeg A42-5 Dual Fuel (Electric and Gas)...
I need a 2x2 brushless fan model # rdm5015s dc 12 volt. where do i find one please?
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
May 10, 2010 | Sanyo /San Ace DC 12v Brushless FAN Assy
I have a rooftop unit 10tons when i turn the fan on it makes a rubbing sound i remover the fan and the motor the motor make no noise I changed the berrings in the fan but it still makes the loud rubbing...
the unit may settled and it is rubbing against something it may be the cover...run the unit on low and see then to high that may lead you to the location good luck
Sep 08, 2009 | Heating & Cooling
Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Loud fan
The fan is rubbing against the fan shroud. it may be misaligned or, the shroud has become loose. try aligning the shroud or making sure that it is screwed on correctly. The shroud mounting screws can become loose. This will allow the fan to rub against the shroud. this will create a loud noise. If during the inspection of the shroud you find that the fan is not rubbing against the shroud, this will confirm an issue that concerns the integrity of the electric motor sator assembly. the windings are bad. have the motor replaced if this is the case.
Aug 07, 2009 | Samsung Refrigerators
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
NEC VT 440 Projector noise
The unit needs to be opened and have the fan checked. If it is out of warranty and you are capable you should be able to access the fan quite easily. It may be rubbing against something or it may have contaminants inside and needs to be replaced.
Jan 25, 2009 | NEC VT47 Multimedia Projector
Loud thumping noise in rear air
Hi, you should check if the blower plastic fan is rubbing against the fan housing ,they get lose with time and make those noises.good luck C1...
Nov 27, 2008 | 2003 Chevrolet TrailBlazer
Lous Noise
It could be the blower fan is loose and needs to be tightened. If so, and you're handy, shouldn't be too difficult. Depends on the specific design.
Jun 16, 2007 | Kenmore 72175 Air Conditioner
Samsung HT-P38 System Logo
265 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
