How to cancel a printing job - Office Equipment & Supplies
  • Anonymous Apr 26, 2009
    It is not listed in my printer files, the doc information had already sent to the printer.  I had a printer jam with some new colour paper and after I removed it has been printing and printing and now I really just want it to stop. I unplugged the power.  Checked for file in printer list and it is not there.. Help please  mfc 9600
  • 446 Answers
Double click your printer, you will see the printing console, click the desired file you want to cancel by holding the right click the select cancel.
or go to edit and select - cancell all doc.
hope this helps
Posted on Aug 01, 2008
Delete a print queue
  1. Click Start, and then click Run.
  2. In the Open box, type control printers, and then click OK.
  3. Right-click the icon for your printer, and then click Open.
    • To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
    • To cancel all print jobs, click Cancel All Documents on the Printer menu.
Jan 11, 2015 | Office Equipment & Supplies
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
I entered a print job that I want to cancel. How do I cancel printing?
Click on the printer icon at the lower right hand corner of your screen.
This will bring up the print spooler dialog. Make sure the print job you want to cancel is selected.
You will find the Cancel command in the menu.
Hope this helps.
Jul 21, 2011 | HP DeskJet 970cxi InkJet Printer
I would like to cancel a print job without losing all of my memory card picture selections. Seems rather silly to lose all your selections if something goes awry with your printer output.
If you are using Windows, you can cancel a print job by opening your Start menu (usually the bottom left corner of your screen) then open Devices and Printers or Printers and Faxes depending on your version of Windows.
Double left-click the name of your printer
Right-click the name of the print job you want to cancel and select cancel print job or right-click a blank part of the printer box and select cancel all print jobs.
Apr 12, 2011 | HP Photosmart 3310 Printer
Unable to delete pending jobs
1. Go to Control panel - Printers .
2. Right-click the icon for your printer, and then click
Open.
3. To cancel individual print jobs, right-click the print job
4. To cancel all print jobs, click Cancel All Documents on
the Printer menu.
Alternatively if this doesnt work you have to restart the spooler service
1.Go to Control Panel - Click Administrative Tools.
2.Double-click Services.
3. Stop the service called Print Spooler.
4. Click Start to restart the Print Spooler. Then click OK.
Hope this helps.
Mar 12, 2010 | HP LaserJet P4015N Printer
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
1,093 people viewed this question
jasbo
jasbo
