Question about QSC MX1500A 2-Channel Amplifier
One of my channel stop working in my qsc mr 1500a is this fixible and how much rounding of would it be to fix it
    Problem Solver:
  • 37 Answers
Sounds like the output chip has been fried just take it to a tech not unless u know what u r doing then just fix it youself
Posted on Oct 22, 2011
Qsc amp no sound 0utput
With amps loss of sound is mostly connected with the devices found on the heat sink. Some amps have transistors for each channel. Others have a single IC often marked with the letters STK. If the amp uses the IC then these can loose one channel then the other. Replacment is the only cure.
Jul 11, 2014 | Audio Players & Recorders
Qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
How do i bridge my mx 1500a because I dont have a manual for it? can u tell me which terminal i can used thanks in advance.
There's a switch on the rear, put this in bridge mode.
Connect you speaker (not under 4 Ohm) on the two red outputs.
Here's your manual.
http://media.qscaudio.com/pdfs/mxusr.pdf
Good luck,
Gerard
Jan 30, 2010 | QSC MX1500A 2-Channel Amplifier
Question similar to ...connect to home theater... What kind of fan noise do these amps (QSC MX 1500a) have if using in a home theater or stereo system in the typical room?
Hi
I work with these amplifiers every day and i can tell you that they not made with quietness in mind.
They are mainly used in a club/disco environment and often mounted in a equipment rack hidden in a closet. Excellent/tough amplifiers if you want power and clean sound ,but
You may find their noise level uncomfortable in a living room.
Hope this help Merry Christmas
Dec 21, 2009 | QSC MX1500A 2-Channel Amplifier
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
Where can i get the used power amps?
i have one qsc 1500a 1000watts awsome doesn't many hours on it.
New Orleans La,70056 were are you from
Mar 08, 2009 | QSC MX1500A 2-Channel Amplifier
QSC 1420 pwr amp
The weaker signal caused by leaky capacitor and change value resistor is need to replaced with a new one so it's works normal again. Your tech did is re soldering the cold solder he did not replaced some defected parts.
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | QSC MX1500A 2-Channel Amplifier
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
105 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
