Question about Vivitar ViviCam X029 Digital Camera
Hello My problem is that every time I try to take a picture "card protected" appears in front of a blue screen, what should I do?
  • 30 Answers
Check if the little lock on your memory card has slided accidentally to "locked" some times is not all the way up but looks unlocked.
Posted on Mar 15, 2011
When I turn the camera on, I immediately get a blue screen with the message "Picture or video is protected." I can review what's on my memory card, but that's what I get when I want to...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 10, 2011 | Kodak EasyShare M863 Digital Camera
Screen reads "memory card is
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 24, 2011 | Nikon COOLPIX L18 Digital Camera
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
mode.
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
When my camera is switched on a message appears on the screen. It reads "card locked". How do I unlock the card, so I can take pictures?
Hello there,
You get this error when your card is write-protected. To unlock it, you have to take of the memory card from the camera. Usually its along the battery compartment. But you have to check the other sides just to make sure. One you have the card, look at the sides for a small switch. Push it the other way around to disable write-protect. Put it back to the camera and test.
Hope this helps you and someone out. Good luck!
Jun 21, 2011 | Pentax Optio E10 Digital Camera
When pressing the shutter button it does not take the picture and shows a blue screen saying "card protected". Is the memory card defective?
Remove the Card and while looking it card with metal contacts facing away and up there is a little white button on top left of card that Button slides up and down up for protected mode down for unprotected slide the button down then reinsert card and try taking another picture.
Thumbs Up if helpful, feedback is appreciated.
Good Luck!!!
Jun 16, 2011 | Vivitar Cameras
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
As I turn on the camera, a message of "this card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 06, 2011 | Casio EXILIM 8.1-Megapixel Digital Camera...
When I try to take a picture with my Pentax Optio W10, I read on the screen "card locked" + icon, and of course no image is recorded. this started happening out of the blue. What to do ?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 18, 2010 | Cameras
What does "memory card is write protected mean?" I can't take any pictures
when i turn on my nikon coolpix the screen says memory card is write protected what does that mean
Dec 07, 2008 | Nikon Cameras
Vivitar ViviCam X029 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
